andyjstone
Tailgate Trim
andyjstone
Sorry if I'm asking a silly question, but I'm just fitting another tailgate on the 205 and the one I am putting on doesn't have the plastic trim across the back.
I want to take the one off the old tailgate and fit it on the new one, but how do they come off/fit on???
Atari Boy
If I remember correctly, you remove the ‘Peugeot’, ‘205’ and ‘GTi’ badges with a sharp blade as they are stuck on then behind them are some metal lugs, it is then just a case of pulling the plastic panel downwards and they ‘should’ unclip.
andyjstone
That looks right, except that it would appear that some time in the past someone lost two of the retaining clips and araldited the panel on :)
chrisj21
There is also one star washer on the inside near the wiper motor to remove IIRC.
cybernck
IIRC, there's a U-shaped clip that holds the tailgate lock in place that also has to be removed (from the inside).
