sam jfm
Driveshafts, All The Same?
sam jfm
are all the tu 205 driveshafts the same?
trogboy
Yep - almost (the Euro Rallye ones as that uses 1.6 gti hubs so has different ends)
You can use 1.6 GTi hubs on standard TU driveshafts just fine - I was running that setup on my XS.
Splines are identical between base model and 1.6 GTi hubs, just the offset differs (1.6 hubs give wider front track)
trogboy
Anthony - Yes you are right! :P I am suffering from a long day of writing reports.
I got confused between the 1.9 hubs and the 1.6 hubs. Stupid really because originally I too used 1.6 hubs calipers and disks on my Rallye but got fed up with the clunk from pads shifting, as the calipers were worn. Now I use 1.9 calipers and disks on the original base model hubs.
I was sure that there was something different about the euro rallye shafts but I can't remember what it is now - perhaps it's just my memory playing tricks :)
they are all the same part number if its a TU engine and MA gearbox :)
paulsupervts84
they are all the same part number if its a TU engine and MA gearbox :P
all the ma shafts are the same, but the be gearboxs the shafts are alot fatter and better
