Rolando 10 Posted November 14, 2009 i'm not sure if this is in the right area but does anyone have any pictures of how they've put their battery in the boot? or is there a how to guid anywhere? thanks Share this post Link to post Share on other sites
paulsupervts84 0 Posted November 15, 2009 i'm not sure if this is in the right area but does anyone have any pictures of how they've put their battery in the boot? or is there a how to guid anywhere? thanks all you need to do is get a battery box and run a cable for the starter motor to the + on the battery and somewhere on the chassis boot floor for a ground. Share this post Link to post Share on other sites
Uberderv 6 Posted November 15, 2009 I bought some thick battery cable and ran it from the boot to the engine bay where it connects to a junction box. From there, all the other bits, ie starter motor etc.. are connected. I bought a black plastic battery box off Ebay and made a metal frame that sits inside it so you can bolt it down to the vehicle and strap the battery to it. For the earth cable I used an old starter cable and attached to the car body in two places (removing the paint first) Share this post Link to post Share on other sites
paulsupervts84 0 Posted November 17, 2009 ideal that look ideal Share this post Link to post Share on other sites
Vili 17 Posted November 18, 2009 Just be sure to fasten the battery to boot floor properly and use cable thick enough. I would use 35mm^2 minimun. Share this post Link to post Share on other sites
paulsupervts84 0 Posted November 18, 2009 i'm using 20mm cables and its fine Share this post Link to post Share on other sites
