Quarryman 1 Posted November 12, 2009 I think i might have disturbed the alternator wiring. After running the car for a few minutes and trying to restart it wouldn't turn over again. A jump start fixed it straight away. Then dead again after a few minutes running. How can i check if the battery is being charged by the alternator? Where can i check the voltages and what should they be? Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted November 12, 2009 Check the voltage first at the battery with the engine stopped. Hopefully you will have aomewhere between 12-12.5v. Then start the engine and check again, you should now see something like 13.5 - 14v indicating the alternator is charging. Share this post Link to post Share on other sites
pablo 0 Posted November 12, 2009 (edited) Try giving it a little rev once you jump start it. My old pinto used to read 12v when idling after being started until it got a little blip then went up to high 13s and stayed there. Edited November 12, 2009 by pablo Share this post Link to post Share on other sites
Quarryman 1 Posted November 12, 2009 Check the voltage first at the battery with the engine stopped. Hopefully you will have aomewhere between 12-12.5v. Then start the engine and check again, you should now see something like 13.5 - 14v indicating the alternator is charging. great, that's what i needed thanks. That f**kin multiplug. I re-wired some it to try fix the starter problem. It didn't fix it and now the battery does not seem to be getting charged so I'm thinking i might have disturbed the alternator wire. What happens if the wire from the multiplug is un-connected? I assume it just doesn't work and gives the symptoms i'm seeing? Share this post Link to post Share on other sites
jackherer 543 Posted November 12, 2009 What happens if the wire from the multiplug is un-connected? I assume it just doesn't work and gives the symptoms i'm seeing? Yes, the battery light on the dash should come on when you turn the ignition on then go off with the engine running. With that wire disconnected you will never see the battery light come on and the alternator wont start charging unless you rev the engine beyond 2 or 3k. Share this post Link to post Share on other sites
Quarryman 1 Posted November 12, 2009 Yes, the battery light on the dash should come on when you turn the ignition on then go off with the engine running. With that wire disconnected you will never see the battery light come on and the alternator wont start charging unless you rev the engine beyond 2 or 3k. thanks, i'll check for the battery light. just to clarify above, the alternator won't start charging until the engine revs beyond 2-3k in all situations or in the 'broken' state (ie no battery light)? Share this post Link to post Share on other sites
welshpug 1,737 Posted November 12, 2009 in the broken state, when its working it'll charge from the second the engine turns Share this post Link to post Share on other sites
Quarryman 1 Posted November 12, 2009 in the broken state, when its working it'll charge from the second the engine turns that's interesting. What is the reasoning behind that behaviour. Does it switch off the alternator with this wire depending on a current reading from the battery (ie its fully charged)? apologies for the simple questions, i'm not too up on the workings of the alternator. Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted November 12, 2009 The alternator requires an exciter current to start it working. This in very basic terms is linked to the battery light on the dash. Once the alternator is excited it will charge away happily. If the exciter current is not there, by about 3000rpm engine speed (6000rpm alternator speed) it is excited enough to start charging anyway. Share this post Link to post Share on other sites
Cameron 16 Posted November 12, 2009 Exciting stuff. (Ohhhhhhhhhhhhhhh!!!) Always wondered why my alt would never charge until I blipped it over about 1.5Krpm, now I know. Guess I should extend my exciter wire then. Share this post Link to post Share on other sites
Quarryman 1 Posted November 21, 2009 Thanks guys. Replaced the wiring to the alternator and all is well. Share this post Link to post Share on other sites
