Sergio205
Unknown Warning Light (+)
Guest torbes
The descripted light is simply the ECU´s "check engine"-light... Why Peugeot decided to use the Cat´s overheat-light... nowbody really knows...
This light appears on magneti-marelli ecu´s evertime you turn on the ignition... and goes dark after 3 or 4 seconds...
Further it appears when serious malfunctions appear in the engines functions....
I think it´s a good idea to read out the errors from the ecu... Should be possible with a normal lamp...
cheers, tob
Warning: I´m not sure if on Bosch-Motronic-ECU´s the lamp has the same meaning!
