aCe
Bx Mi16 Wiring Details
aCe
Heys guys, i have done a search but nothing comes up. I have a BX loom (green and yellow) and need in depth detailson how to wiring it up.
I have removed the sensors 8v loom and thats bout it
please help
Ryan
The BX loom is very simple to wire up.
- Yellow spade connector about 6" from the ECU = fuel pump positive.
- Thick blue wire at the far end of the loom = 12V from the battery
- White 2-pin plug near the middle = one pin is switched 12V from the ignition barrel, the other is a feed for the rev counter.
IIRC those should be enough to get the engine running.
