djinuk
Spec Your Suspension Setup
kilauea
Engine type: 1.9 8v circa 123bhp
car use: road / track day
ride height: -30mm
Front setup: -30mm Autofive springs, KYB AGX shocks, grp N rubbers.
Rear setup: KYB AGX shocks, Grp A rear mounts.
Springs seem a bit harsh, but very predictable and solid feeling otherwise.
Shocks adjusted to 2 at front and 6 at back.
Engine Type - 1905cc 8v, 1.6 Be3 with Quaife ATB.
Car use - road & track days.
RIDE HEIGHT approx -35mm .
FRONT SETUP
Koni sport top adjustable "yellow" struts with Red springs as supplied in kit, group N top mount rubbers, upper & lower strut braces. Shock set to about 60% stiffness.
205 wishbones.
REAR BEAM
20mm torsion bars, 24mm arb
Bilstein tarmac group N shocks
zx arms.
Solid beam mounts.
Change to come over winter with stiffer front springs, slight lowering & 21mm torsion bars.
Graham.
Veero
205 with standard Mi16 engine road car
Ride height, Circa -20mm
Front setup - 306 GTI6 struts. Eibach 20mm drop springs, OMP upper strut brace
Rear setup - standard bars on 1.9 axle with KYB dampers
If anything the dampers are a little stiff on the back, shortly changing to 306 items.
Edited by Veero
davidc
Which / who's eccentric top mounts are most people using ?
Cheers,
David
davepug205
Engine Type - ..............
Car use - none yet
RIDE HEIGHT - .................
FRONT SETUP
Fully seamwelded subframe with Rose jointed tubular wishbones, fully adjustable type for castor/camber/ rollcentre,
406 hubs modified to lower rollcentre,
180lbs springs on bilstein tarmac inserts, coilovers bodies, with eccentric top mounts
REAR BEAM
Xsara vts rear beam on custom solid mounts (21mm torson bars)
BRAKES
None yet
Eccentric mounts where made by MED
Edited by davepug205
Engine Type - S16 220hp BE3 4.7:1 Quaife ATB.
Car use - Supersprints & Hill climbs
RIDE HEIGHT approx -40mm .
FRONT SETUP
Grp A adj. wishbones
Custom valved Bilsteins
350lb springs
REAR BEAM
23mm torsion bars
25mm arb
Bilstein shocks
Solid beam mounts.
205freak
Engine Type- xuj5a 1.6
Car Use - weekend car
Ride Height Front- 35mm
Rear - 45mm
Front Set Up- Koni Sport 35mm
Rear Set Up - Koni Sport 45mm
Gr.N Beam/engine mounts
tdr_1976
CAR USE
Engine Type - TU3S XS
Car use - Road/Endurance Rallies
RIDE HEIGHT - Standard Height on Rear and standard plus 1" on Front
FRONT SETUP
Front suspension - Koni Adjustable Struts, with 205 Diesel Springs
REAR BEAM
Dampers - Standard
Torsion bars - Std
Arb - Std
With Group N bottom engine mount.
Edited by tdr_1976
Bigtimmy
CAR USE Track and occasional road
Engine Type - 1.9 gti Baffled sump, K&N, shiny bits, be3 box soon to have Trans X plate diff
RIDE HEIGHT - not sure. But 'sensibly lower' than standard.
FRONT SETUP
Front suspension - Gaz Golds, 300lb springs, 309 bottom arms & shafts, eccentric top mounts 309 arb and strut brace
REAR BEAM
Dampers - Bilstien Tarmac spec (yellow)
Torsion bars - 24mm
Arb - Std, soon to be 28mm
Solid beam mounts.
lemmingzappa
Engine Type - Standard 1.6 GTi
Car use - Road
Ride Height - Approx -30mm to -35mm Front & Rear
FRONT SETUP-
Gaz GHA Coilovers
180lb Springs
Standard GTi ARB
Baker BM Group N Top Mount Rubbers
REAR BEAM-
309 Rear Beam
Standard 309 Torsion Bar
Gaz GHA Dampers
Baker BM Group A Mounts
WHEELS & TYRES-
1.9 Speedlines on ZE-912's
Cameron
Oh go on then.
Engine Type - XU9J4RS :)
Car use - Track (& eventually hillclimb)
Ride Height - Something like 60mm front, 80mm rear.
FRONT SETUP
Gaz Gold dampers, 350lb springs
Standard ARB
Eccentric top mounts & 309 arms
-3mm camber
REAR BEAM-
Gaz Gold dampers, 24mm TB's
Standard ARB
ZX arms
-1.5mm camber, 0mm toe
WHEELS & TYRES-
S2 106 Rallye steelies
Yokohama AO48's (soft)
JonnyGee
still setting car up and finishing building but where is everyone getting the 309 beam torsion bars and arb's please? 24mm ect?
Alot of them no doubt are ex 205Parts items.
If you look through the Group Buys section i think 309PUG can still supply them. Or you can get a 306 GTi6/Xsara VTS ARB and cut it down & respline it/weld it as a cheap option.
ravydavy
ENGINE TYPE - Honda integra type r dc5 + box.
Car use - track mainly. Tried road and its awful.
Ride height - -50mm all round
FRONT SETUP - bilstein group A with 350lb springs
compbrake rose jointed arms - can't get enough castor on them.
eccentric topmounts -2 deg camber and bout 3 deg castor.
REAR BEAM - 309 beam with 23mm arb.
306 tarmac spec billies
solid mounts
WHEELS
pro race 1.2's with r888 and a048's
dunlop slicks yet to try
swordfish210
Engine type: 1360cc Alloy block 8v TU
Car use: Mainly track
Rideheight: Not sure, can't remember what it was as standard
Front Setup
1.9 Gti front subframe
309 GTI wishbones, Peugeot bushes
PTS Bilstein coilovers, Fixed platform
Bilstein Tarmac inserts
300lb 7" springs
Compbrake eccentric topmounts, mounted on top of the shell in the 11 and 1 o'clock position
Quaife quickrack
Standard GTI ARB (will probably disconnect in Hillclimb mode)
Rear Setup
1.9 GTI beam
Solid BBM mounts
24mm torsion bars
ZX trailing arms
Saxo VTR 22mm ARB
Koni Yellow dampers
Wheels and Tyres
Citroen C5 "Steels"
Yokohama A048 tyres 195/50/15
It's pretty stiff :mellow:
Edited by swordfish210
tomcolinjones
Engine type: 1360cc Alloy block 8v TU3+w-s (weber DGV fitted)
Car use: Road Rally and Fast road sometimes
Rideheight: a little higher than 1.9 gti
Front Setup
1.9 Gti front subframe (reinforced allong with warious shell braces)
309 GTI wishbones, powerflex'd
Avo adjustable dampers, Gravel spec springs (standard height)
standard 1.9 arb, powerlex bushes again
modified 10pt cage, upper + lower strut braces. PAS rack(recon). new ends
Rear Setup
1.9 GTI beam, new standard dampers
Solid BBM mounts
24mm torsion bars
on the road i use a set of 1.9's with some eagle f1's.. the old ones.
it wants to go a litle lower on the front idiealy. but i need the clearence for the road rallys.
Stu
Mine is as such:
Mi16 on Webers and Megajolt, PeterT inlet cam, etc etc approx 185bhp. Mainly track use, occasional road work.
Front:
Adjustable Koni's with generic GSF 35mm lowering springs
BBM top mounts
309 bottom arms and shafts
Stock ARB
OMP Strutbrace
Stock hubs/uprights
Rear:
309 GTI beam and TB's
Adjustable Koni's
22mm ARB
Group A mounts
OMP tenpoint cage with additional gussets as i saw fit :lol:
Brakes:
Front - GTI-6 Disks/calipers, Mintex 1155's, 5.1 fluid.
Rear: Stock 205 1900 GTI setup with grooved disks and Mintex pads.
Tyres:
Road: Standard Speedlines, Parada Spec 2's.
Track (dry): Bridgestone Potenza "full slicks"
Track (wet): Dunlop SP Sport "wets"
StuF215
Engine type: 3.0L V6 ES9J4
Car use: Road only atm
Rideheight: around -10mm front , -30 at rear
Front Setup:
309 GTI wishbones, ARB
306 Hubs, 406 shafts
Gaz GHA's 275 lb springs
Japspeed strut brace
Rear Setup:
309 beam with Gaz GHA's
Brakes:
307 calipers and disks on front
On rear I have some calipers I found on 206 estate
Tyres:
I use Yoko Paradas
Edited by StuF215
