Sven_2k4
[misc_work] 1988 205 Cti Back From The Brink.....
Sven_2k4
Hi all this is Mya an Ebay speacial that me and the other half bought to restore and keep us busy over the winter.
I'll add lots of pics as and when we crack on with her, so keep an eye out
She's a 1988 1.6 CTi, advertised as needing a little TLC....... lets wait and see!
'Known' faults currently are:
1. Windows wont open
2. Drivers Door full of water ( coincedence?)
3. Fuel guage has a mind of its own
4. Clutch is 'interesting'
5. small rip in the roof
6. most of the trim clips on the outside are missing or loose
7. Engine in need of an overhaul (job to do in works time me thinks ;o) )
8. broken rear bumper and fog light
9.cracked front fogs.
Wish me luck! :D
Sven_2k4
Right bit of an update......
after stripping down the doors the reason for the locking and windows not functioning may have something to do with the after market goodies added to them and that every joined wire is merely twisted together with a bit of tape! Grrrrrr! :ph34r:
Also the weird start from a flick switch seems to have something to do with an alarm/immobilser it once had that bits of have been hacked out. Put all the wiring back to original but now have developed an odd fault. When starting the engine the feed for the starter solenoid stays live and keeps the motor engaged when the engine has started.......think it may have something to do with the ignition switch so thats my next port of call.
More and pics to follow later ;o)
PhilCTI
Good luck with the CTI,
Reminds me of when we bought ours as a winter project! took rather longer though,
Electrics have often been hacked, I found 4 alarms in different places, eventually I got a replacement dash and unhacked loom from Miles which helped,
Doors can often fill with water as the bottom door window rubbers shrink, just make sure the hole at the bottom of the door is clear to let the water run out, or drill more holes!
I kept some of the photo's of the work at
Photos
If link doesn't work, look up Pillowjo on Fotki photo site, might help in future to see how things are,
Phil
Sven_2k4
Time for todays end of play update......
I've completely removed all the aftermarket goodies, including the two sets of door actuators, the electric (at one time) windows, the inop alarm and immboliser.
I've also tried to restore all the wiring and fix all the bits that dont work i.e the oil pressure guage (broken terminal) and the broken ignition switch.
http://i307.photobucket.com/albums/nn312/s...TI/DSC00001.jpg
Cracked fog light grill and bumper seem ok
http://i307.photobucket.com/albums/nn312/s...TI/DSC00002.jpg
Not pretty and half the wiring and pipe work is perished
http://i307.photobucket.com/albums/nn312/s...TI/DSC00003.jpg
Bit of a dent in the wing otherwise seems ok
http://i307.photobucket.com/albums/nn312/s...TI/DSC00005.jpg
Few dents in the boot lid
http://i307.photobucket.com/albums/nn312/s...TI/DSC00006.jpg
Cracked bumper and cracked fog light
http://i307.photobucket.com/albums/nn312/s...TI/DSC00007.jpg
Piniafarina badge is a bit loose
http://i307.photobucket.com/albums/nn312/s...TI/DSC00008.jpg
Dent in the wing
http://i307.photobucket.com/albums/nn312/s...TI/DSC00011.jpg
http://i307.photobucket.com/albums/nn312/s...TI/DSC00013.jpg
Curious wiring.......... :lol:
http://i307.photobucket.com/albums/nn312/s...TI/DSC00014.jpg
dash out
Sven_2k4
http://i307.photobucket.com/albums/nn312/s...TI/DSC00015.jpg
Stripping out the aftermarket bits
http://i307.photobucket.com/albums/nn312/s...TI/DSC00016.jpg
Pink wire attached to......well......nothing
http://i307.photobucket.com/albums/nn312/s...TI/DSC00017.jpg
Brown 3 pin plug at the back of the block that doesn't seem to connect to anything ......any ideas?
http://i307.photobucket.com/albums/nn312/s...TI/DSC00018.jpg
Lots of pipes and wires that arent joined up........ they'll all go back together soon
That one isn't meant to connect to anything, its used for setting the ignition timing with a special bit of equipment that Peugeot dealers used to have, these days its totally redundant.
Sven_2k4
Ahhhhhhhh..........That's one less to worry about! Cheers ;o)
Paulmac19
Hi ya i will be following this closely i am trying to do the same to my cti
but my expertise is nil when i comes to working on car
i am a bit heavy handed when i comes to things lol
ian_p
that should keep you off the streets for a bit!
good luck, i wish i had room for a winter project!
escort looks sweet too :D
jord294
nice little project you got there pal.
didn't realise, but you are fairly local aswell :D
Sven_2k4
Hey all
Thanks for the comments!
Bit of an update, since yesterday. Since rewiring the ignition back to original She's developed a strange habit of continuing to throw the starter into the flywheel even after the engine has started. Does anyone know the colour or location of the starter relay (if there is one) before i slash my hands to pieces taking the motor off to look at the solenoid......?
Just a quickie also, whats the deal with editing the linked photo's from photobucket? Surely a restoration thread is ment to have pictures?
Sven ;o)
Looks like they were a bit too big, some people don't have very fast internet connections and it makes the page extremely slow to load for them. Also it can mess the layout up if they are very big.
from the rules:
if the image is greater than 800x600 pixels, put up just a link, without IMG tags,
or resize it to a smaller filesize before uploading.
thread with info about resizing pics:
http://forum.205gtidrivers.com/index.php?showtopic=62205
Sven_2k4
Ah thanks for that! Noted!
Cheers Sven ;o)
cybernck
The size is irrelevant as they will be displayed shrunken, but the filesize is important.
As you're hosting images on photobucket, make use of their thumbnail code.
This makes for a very neat and quickly loading thread ;).
Thanks.
Sven_2k4
Bit of an update.......
Been having a bit of a hunt on the old bay for bits for the CTi. Managed to get a complete lock set for a rather generous £25, an oil pressure sender for £5, and some other odds and sods.....
Fingers crossed when i've sorted the valves out on the XR3i ( the other half snapped the cam belt) I'll get on with the CTi.....
Pictures to follow
Sven ;o)
Lan
Nice car, would be nice to see one round here theres not many GTI's but CTI's are just unheard of other than a few ones I have seen in scrappies :lol: there probably still there infact up in Tarporley not far from skip browns can't remember which one though.
Sven_2k4
Quick update.....
now have the lock up and the CTi is in it!
also in the mean time i've got a set of front fogs, a tonneau cover, a Tachymetric relay, and a complete lock set.
All i've got to do now is strip the car down repaint it reassemble it and then get her gone for Project GTi!!!!!
Sven_2k4
Hey all another update on the Cti, spent most of today trying to sort the 'Curious' wiring and plumbing of the air/fuel intake bits.
at the lockup
everything from the filter to the manifold off...... with 2 nuts and one bolt holding the whole lot on. Bodges galore!!!!
SAD valve missing the wiring ( no where to be found ) and missing the pipe work....... where should it go to? Andwhere does the wiring come from?
Inlet manifold off the car........ odd pipe with a mini sump plug jubilee cliped on blanking it off....... think this should be connected to the SAD?
EdCherry
Indeed that pipe on the bottom of inlet manifold is for the SAD.
Sven_2k4
well it was .......... lol ..........any ideas where i might try tracing the wiring for said valve?
EdCherry
Should be on the ECU loom that comes from under the inlet manifold and over the top engine mount, trace it along and find all the plugs coming off of it.
Sven_2k4
Cheers for that..... I'll take the sprial wrap off tomorrow see if i can trace it.
Also any idea's why the starter would still try and fire in after the key is released? traced the loom back to the fuse board, cant find it shorting out to any 12+feed?
Sven_2k4
which one is it? and where?
Guest
