chrisj21
[engine_work] 1990 205 1.9 Restoration And Upgrade.
chrisj21
Chris, is it finnished yet?
Affraid not Mark, Daz the slacker let me down on Saturday :);)
Although with some of the quotes i've been getting today for insurance it looks as though it will be on it's way to a new owner when it's finished ;)
Hoping to put a few hours in this evening, get the head on and timmed up.
Tesstuff
Although with some of the quotes i've been getting today for insurance it looks as though it will be on it's way to a new owner when it's finished :D
You lying little sh1t ;)
chrisj21
All i remember is some text message saying you had only just got signal or some excuse and you couldn't make it. ;):)
Tesstuff
Selective memory there Chris? :)
I remember a text from you THREE HOURS before mine saying you were really busy at work and probably wouldn't be working on the car today :)
Buffooon ;)
chrisj21
You'll be pleased to know i've saved the fuel rail bolts and injector clips for you Daz, wouldn't want to spoil your glory :wub:
I'm hoping to have it running by the 7th March now, the list of jobs is as follows.
Remove the stuburn top engine mount from the body and install new mount.
Get new bottom mount pressed in to yoke
Get new bottom fork bush pressed in
Fit new bottom pulley to engine
fit head gasket
Fit head to engine and time up
Fit starter and alternator
Swap the vts diff for the 205 one
Fit clutch, gearbox and new driveshaft oil seals
fit non pas rack
Attach the inlet and exhaust manifolds
Get engine fitted in place
Fit various clips, light wiring etc
Fit the wiring and wire up the engine.
Mount the ecu
Fit driveshafts, hubs and brakes back on
The list is more for my own use really, i'll mark things off as i go along.
Quite a list really so i better get cracking.
marksorrento205
Is there a reason why you are ditching the pas? The gti6 pas pump and pipework set up is so easy to plumb in. I have a pressure and return pipe to suit if you decide to keep it. I will pm you later about pressing the mounts in as I have a press :wub:
chrisj21
My racks had it to be honest Mark, i got a cheap enough non pas rack from simes on here and i miss my old 1.6 with non pas so i'll give it ago. I also plan to fit a west midlands motorsport quick rack in the near future.
Indeed you have i forgot about that, I'll await your pm :wub:
I'm after a 309 beam tube if you come across one or know of one?
marksorrento205
I will send a pm in the morning when im at work :ph34r: How bad is the insurance quote? I only know of one 309 tube at the min but its spoken for. Jord294 may have one. He is mr 309 :wub:
chrisj21
Bad enough, i'd set myself a budget and it far exceeds it.
I don't think Sophie will be too pleased and we're just looking at getting a new scirroco or another mini but the john cooper s works r56 model so thats going to enough as it is what with 26k price tag.
It may just become a weekend toy but we will see. Who are you insured with Mark if you don't mind me asking?
marksorrento205
Direct line all mods declared :)
chrisj21
fit head gasket
Swap the vts diff for the 205 one – Half done, just need to seal up the diff houseing
fit non pas rack
Mount the ecu
Getting there! slowly.
Managed to time the engine up after two attempts, turns out the original dampered pulley was out a touch, fitted miles' bottom pulley and all was fine. I'm slightly unsure as to whether i've tensioned it to tight so i'll have another look at that tonight, i can just about twist the belt with my fingers 90degrees.
I had planned to get the clutch on but lost my alignment tool so i'll pick a new one up this week.
Any recomendations as to what to seal the diff housing with?
Edited by chrisj21
chrisj21
fit head gasket
fit non pas rack
Attach the inlet and exhaust manifolds Exhaust manifold has been cut and will be welded this week.
Get engine fitted in place -Just waiting for the above
Mount the ecu
Nearly there now.
I've loads of pictures and info to write up which i'll do tomorrow, hopefully someone will be able to make use of it in the future, or not.Gearbox was a bit of a pain but went on with the second attempt, couldn't quite get the fork in the right position the first time.
More to follow. :mellow:
Edited by chrisj21
twoker1986
glwtp
chrisj21
Update time.
With the engine basically re assembled and ready to drop in i've been working on removing any rust from the engine bay and getting ready for paint.
I'm not looking for a concourse finish here, just something to last well for a few years until a full car respray is in the cards.
I've done about 8 hours now and removed all the rust using the wire brush and drill, sanded down any minor bits and primed. I slowly worked my way around making sure all the rust is removed, de greased and sanded.
Rust removal from the inner wing
Primed first with red oxide
opposite side
With the inner wings primed i moved to the outer slam panel areas
Then down the chassis rails.
Then primed the whole area with zinc primer
The opposite side has also been done and the strut tops and bulkhead rubbed down ready for primer.
Finish priming tomorrow and then paint on Monday.
Edited by chrisj21
chrisj21
All painted !!
And looks really good, really impressed with the results.
I'll let the pictures do the talking :ph34r:
So happy with the results, i put about 8-9 hours in on the preparation, sanded all by hand and removed a few bits of rust with the drill. I made a canopy to cover it and protect from the dust which worked really well.
Colour match is also much better than i expected.
Just need to clean everything else and put it back together.
:D
Daviewonder
Looks like a good job :D , looking forward to seeing it all back together. I hope the servo will get a coat of paint before it goes back in :lol:
chrisj21
Funnily enough it's off and ready to paint :lol:
Everything will get a good clean and the engine a lick of paint too.
Thanks for your comments :P
Guest
