justinv 4 1 Cars Posted October 27, 2009 Anyone knows if it is difficult to get the front fenders removed ? Share this post Link to post Share on other sites
welshpug 1,627 Posted October 27, 2009 I guess you mean the front Wings/Wheelarches? yes they are very difficult to remove due to the amount of seam sealer that was used in the factory to bridge the gap to the inner Wing and keep water out, this it does very well! What reason do you have for removing them? if its damaged and to be replaced then you dont need to worry about damaging them and brute force will suffice, otherwise take your time or you will bend them. you need to cut away as much of the sealant as possible with a sharp sturdy knife, heating it up with a heat gun will make it easier. good luck! Share this post Link to post Share on other sites
