lagonda
Reverse Light Comes On /stays On When Raining!
lagonda
As it says really...anyone else had this happen & know what to look for?
SurGie
Sounds like you need a new rear light sensor.
The sensor works by stopping the light coming on when not in reverse gear all the time, then when you use reverse gear
the sensor stops working so the lights will work when reversing.
AFAIK the sensor is at the front top part of the box with two wires coming out from it, i cannot remember the colours of them.
Hope this helps.
steve@cornwall
with this and your cutting out problem are you sure you don't have an issue with dampness in the engine bay?
lagonda
Hi Steve,
No, it's not my car, this is for the guy who lent me his AFM (Phase 1 GTi, E reg), not yet a forum member.
Very quietly....the CTi is running fine at the moment.....sssssssh don't let it hear.
Tangy7
hi all,
the reverse light seems to stay on when it is wet weather. Does anyone know where the wiring connectors are situated?? Also where exactly that sensor is?? Top part at front doesnt really ring a bell for me.
SurGie
If you look around at the top of the gearbox, there will be a sensor plug with 2 wires coming out of it, cream in colour usually. There will
be wires coming out of it and they are the only electrical wires attached/linked to the gearbox its self, apart from the earth one that is a thick
single electrical wire. The sensor screws out after you have carefully pulled the wires out of the sensor.
Or it could have one or both the wires slightly coming out and water has got in somehow.
Take a good look around at the gear box.
Tangy7
ok thanks, I will have a look and when you say gearbox you mean under the car right?
SurGie
No not underneath, at the top of engine to the right side/ near side of car, you should easily spot the sensor and wires with a good
torch.
Tangy7
no wonder I couldt see a blooming thing just then. Weather and light permitting I'll have another look. Saw a couple of plugs but dismissed them. any recommendations on removing any bits to get a better view/access?
thanks
might check fusebox in case it has worked loose.
Does the light stay on if the fuse is blown? although I don't think it has blown because the rev counter is on the same circuit no? that still works.
Edited by Tangy7
SurGie
If there is any thing wrong with the sensor/wires/fuse then it will stay on for good till it has been rectified.
It would help if you removed the air filter pipes that go towards the manifold on top of the engine above the
gearbox area. As said before the sensor plug should be a cream colour, which as far as i know 1 green/ 1 purple wire coming out of it.
Please don't quote me on the colours as its been a while since i replaced my reverse sensor plug.
Edited by SurGie
large
thanks
If the fuse had gone the light would not come on at all!
I am happy to have a look if you want "butt" drop me a pm.
Tangy7
not had another chance to look yet. But Large, might take you up on that offer mate. Thanks.
Weather has been rather crap. Maybe I need a new switch.
large
No problem. I may have one out the back in a box i will have a look tomorrow.
large
Just to update this, I had a look and it was the switch.I did not have one, as the one I had from a be3 box was shorter. Would it have worked anyway?
