wardy18
Engine Codes
wardy18
Just a quick one, why do Peugeot / Citroen engines have 2 engine codes, ie XU9 and D6B
Im thinking that the XU9 part is actual engine and the D6B part relates to the particular model its fitted to to point out that there is slight variations to meet that models specs, ie power steering, 8v/16v etc etc
Can someone please confirm!?
Best Regards
Simon
ps. sorry if this is in the wrong section, wasnt too sure
boombang
First two letters relate to the series. Number relates to capacity.
Also you've missed out there is another part to the code. For example XU9J4
The J relates to it being injection and 4 is number of valves per cylinder.
Last bit relates to the specifics to that variant of engine. i.e. XU9J2A
The D6B bit relates to the head specifically. Unsure what other heads there are about tbh, or what means what of that code!
Edited by boombang
wardy18
Ah ok a little light shed, thanks
In that case do you reckon you can convert the following:
XUD9Y - Peugeot 205 1.9 TD
XUD9TF - Citroen Xantia 1.9 TD
Obviously they both PSA engines (XU), Diesel (D) and 1.9 (9) but what does the "Y" and "TF" stand for in each?
Many Thanks
Simon
They refer to the variants of that particular engine, usually with the diesel engines T signifies a Turbo engine, the last numbers I don't know the significance of but the Fuelling, Turbo and EGR systems vary with the engine codes.
wardy18
Does anyone know any good sites that i can get Peugeot and Citroen engine codes off?
wardy18
specifically i need to confirm the engine code for the 205 1.9 TD being XUD9Y but then is it XUD9TE?!
ive been looking for hours and cant find anywhere that confirms it!!
to my knowledge the 1.9 Turbo was never fitted to the 205, only the 1.8D N/A, 1.8DT, and very late 1.9 D N/A.
Richie-Van-GTi
You find differences in the 1.9 td specifically as there are different variants for turbo make, intercooler type and position and also a difference in oil coolers. Dont ask me what the differences are as usch but all the engines do interchange. Its just ancilleries that differ.
wardy18
yes sorry its not a turbo
DrSarty
Try all of these:
http://forum.205gtidrivers.com/index.php?s...7&hl=XU7JP4
http://www.peugeotclub.info/page.php?65
http://www.peugeotlogic.com/workshop/wshtm...ecs/vincode.htm
http://en.wikipedia.org/wiki/PSA_XU_engine
Another thing that could help you is looking through the diesel variants of the correct year in Miamistu's Online Parts catalogue. That way you can check compatibility of items across models.
