feb 47 Posted October 7, 2009 Hi, My other half just told me that the horn in the 205 has stopped working. I had it replaced 3 years ago with an electric one (new) from a 1.6 Any hints as to where she can start looking at? Cheers Share this post Link to post Share on other sites
tri_longer 25 Posted October 7, 2009 Hi,My other half just told me that the horn in the 205 has stopped working. I had it replaced 3 years ago with an electric one (new) from a 1.6 Any hints as to where she can start looking at? Cheers i'm sure this has been covered many a time, but rather than telling you to do a search, I would suggest that a couple of quick checks would be to get a multimeter and check that you have power to the horn. If you have, then check the earth. If this is ok then it may well be duff. Also check the fuse If you haven't got power at the horn then you may have a break in the wiring or a fault with the stalk. Cheers Chris. Share this post Link to post Share on other sites
jason7579 5 Posted October 7, 2009 The first 2 checks I would do would be to connect the horn directly to the battery to make sure its working and (as above) check there is power at the horn (using a multimeter or a spare bulb, I have a spare interior light just for checking things like this). Share this post Link to post Share on other sites
GLPoomobile 958 Posted October 7, 2009 If the horn is fubar, replace it with a Steibel Nautilus. No more puny farting sounds with one of those bad boys! Share this post Link to post Share on other sites
feb 47 Posted October 7, 2009 Cheers guys, which side of the car is the horn located? Share this post Link to post Share on other sites
jason7579 5 Posted October 7, 2009 Pretty sure its passenger side (in my H reg 1.9 anyway) Share this post Link to post Share on other sites
joe1joe 3 Posted October 9, 2009 yep passenger side, and if ur unluck like me then u will need a fuse board!!! well thats if ur heated rear window doesnt work aswelll!!! Share this post Link to post Share on other sites
