Guest Kit
Max Wheel Width For A 205 1.9?
Guest Kit
I've seen some 15x8 ET25 wheels that I like allot, i'm actually used to driving a 205 without PAS and ET15 14x6.5 wheels, I was thinking about running them with a stretch of 195/40 and getting the arches rolled, will this be sufficient?
Edited by Kit
James_R
To fit I think you'll need spacers to bring the ET to 0 when I test fitted J8's with ET0 it was pretty tight. they will stick out but with 190/50's on them the tyre should be with in the arch, but not ideal.
Guest Kit
Would i be right in saying that the hub to suspension would have to be more than 12.7cm on a et25 8x15 wheel?
I would get more clearance on coilovers wouldn't I, or is it the rear which poses the problem?
Edited by Kit
James_R
You gain no real benifit on coilovers in terms of wheel clearance, it's the hub offset, 1.6 hubs would give a 10mm more clearance, but that would be a whole host os fun swapping them them just for the sake of spacers.
