Silky
Heater Matrix Pipes
Silky
I have changed the heater matrix, have also just dropped the engine back onto its mounts.
Question is, which pipe from the engine goes to which heater matrix pipe ?
One of the pipes has the bleed valves on it, does this go top or bottom.
Which way round are they ?!
The pipe with the bleed screw (ie the one from the lower coolant distribution block) goes to the upper of the two :ph34r:
