andyjstone 6 Posted September 18, 2009 I noticed at the weekend that my radiator is quite loose. Is this normal and what should hold it in? Share this post Link to post Share on other sites
JayCC 0 Posted September 18, 2009 It normally slots in at the bottom, then two sping clips at the top. Then tops hose and bottom hose sort of hold it in place. Mine is the same. Share this post Link to post Share on other sites
mattbenselin 0 Posted September 18, 2009 The spring clips are attached the fan shroud and hold the rad in place along with the hoses and bottom locating holes as mentioned. Share this post Link to post Share on other sites
Rob Thomson 6 Posted September 18, 2009 Is the rad loose in the cowling, or is the cowling loose in the bodyshell? There should be some rubber buffers that support the bottom of the cowling on the cross-member, but these are easily lost making everything rattle around. Share this post Link to post Share on other sites
andyjstone 6 Posted September 18, 2009 Is the rad loose in the cowling, or is the cowling loose in the bodyshell? There should be some rubber buffers that support the bottom of the cowling on the cross-member, but these are easily lost making everything rattle around. I can't really see, but I think that must be the problem - it doesn't seem high enough to enable the spring clips on the top to hold it in place - do the rubber buffers at the bottom lift it up? Share this post Link to post Share on other sites
Rob Thomson 6 Posted September 18, 2009 The rad is held into the cowling by its clips at the top and two pins that push into rubber bushes in the cowling at the bottom. The buffers support the cowling so won't affect the way the clips hold the rad. The other thing to check is the rubber bushes where the rad is located into the cowling at the bottom. These can also go missing... (Can't believe how complicated I'm managing to make this sound - it's just a rad, a cowling, two springs, and four bits of rubber...) Share this post Link to post Share on other sites
andyjstone 6 Posted September 18, 2009 (Can't believe how complicated I'm managing to make this sound - it's just a rad, a cowling, two springs, and four bits of rubber...) I think we need a sketch Share this post Link to post Share on other sites
swordfish210 20 Posted September 18, 2009 Cable ties On my XT anyway due to me ditching the cowling to save a bit of weight Share this post Link to post Share on other sites
daveyboyblack 1 Posted September 18, 2009 Me too.. cable ties. In fact up until recently... just 1 cable tie! I've now improved it 500% Share this post Link to post Share on other sites
