tidypug
Bmc Cda Air Filters, Opinions?
tidypug
I've been considering getting a bmc cda air filter to enable me to get cold air into the engine helping me to keep inlet air down. Does any one have any experience with these?
http://www.bmcairfilters.com/infoCDA.asp
They are quite pricey new so would try to get a second hand one from Ebay. I'm not too sure how big an ID I would need to feed my engine without it being a restriction, I was thinking about an air filter that came from an Impreza, Audi or something similar.
I think they do 3 sizes typically apart from the special application kits, one for up to 1600, one for over 1600, and one for big power applications.
most likely want the middle one which is the CDA85-150, that one is 85mm inlet/outlet, 150mm Diameter and 200mm long.
Edited by welshpug
tidypug
that should be ok, I just didn't want the inlet/ outlet to be restrictive as mine is running a supercharger
Pob
Whilst looking around for parts I came across this... The only difference is its 75mm inlet & outlet and 20mm smaller in diameter. Not sure if it's any good....
http://www.cbsonline.co.uk/remote-carbon-f...rbfil-861-p.asp
Dan
Edited by Pob
Pob
That looks quite good. Do you know what the air filter is rated to? :wub:
Haven't a clue. Best bet is to email them, they might know.
Dan
