smokey 0 Posted August 21, 2009 Hiya guys I've just recieved a big box of bolts and screws, plus fittings for bumpers, trims etc. Over £200 ouch!! I was wondering before i fix everything to the car, is there anything i should do to protect the screws etc. Before they all corrode and rust together like the original ones? I know this will probably take a while but thought i would ask anyway. Thanks Share this post Link to post Share on other sites
welshpug 1,623 Posted August 21, 2009 tons of copper grease and substitute as many with Stainless where possible. Share this post Link to post Share on other sites
jimistdt 1 Posted August 21, 2009 I use Alu anti-seize, or you could do what magic has done (see his thread) and get them all coated. (£££££'s) Share this post Link to post Share on other sites
davev 1 Posted August 21, 2009 may sound a bit cowboy but id put either a dollop of grease or underseal on them(after ive tightened them up) Share this post Link to post Share on other sites
Last Legend 0 Posted August 21, 2009 If it was me I'd spray them with some clear laquer,or even better this- http://www.frost.co.uk/item_Detail.asp?pro...rfaces%20(312g) Share this post Link to post Share on other sites
cRaig 265 1 Cars Posted August 21, 2009 Im going to see about getting all the bumper bolts and brackets zinc plated, as I replaced them all with new geniune pug ones a year ago and noticed they had all started rusting quite badly. Worth the outlay I think, as it should make getting the bumpers off easier, and hopefully last a bit longer. Share this post Link to post Share on other sites
welshpug 1,623 Posted August 21, 2009 they are all plated when you buy them new, and I would imagine it'd be a bit tricky to re-plate the bumper bolts as they have plastic moulded onto them. Share this post Link to post Share on other sites
cRaig 265 1 Cars Posted August 21, 2009 mm, its the end bolts and brackets that had all gone rusty rather quickly on mine, not sure abou the middle ones with the plastic on them, as I havent recovered many lol. The rear bumper brackets had suffered badly as well. Share this post Link to post Share on other sites
SurGie 54 Posted August 21, 2009 I got 30 shouldered studs for the TB end bolt retainer's zinc coated for £20 cash in hand, so for the whole lot i should think you could get them sorted out with zinc for around the £100 mark, depends how much you need doing. Then if you have them all sorted this way, surround the thread with a little bit of copper grease. Share this post Link to post Share on other sites
Cameron 16 Posted August 21, 2009 Just replace them before they corrode together if you're that worried about it. Share this post Link to post Share on other sites
Redtop 14 2 Cars Posted August 22, 2009 I got 30 shouldered studs for the TB end bolt retainer's zinc coated for £20 cash in hand, so for the whole loti should think you could get them sorted out with zinc for around the £100 mark, depends how much you need doing. Then if you have them all sorted this way, surround the thread with a little bit of copper grease. Yep thats what we do. I think the whole set of bolts for the last car I did was £30 cash. That was all the brackets etc and with the choice of yellow/gold or silver. You can't do parts with rubber or the likes of the bumper bolts with the plastic end on them though, but all other stuff you can. They will corode eventually, not alot you can do unless you can keep the car salt free underneath and dry. I'd try to avoid the copper grease if possible as it's messy and if you have to take anything off again that has been done with it, the stuff gets everywhere! Share this post Link to post Share on other sites
jord294 87 Posted August 22, 2009 (edited) i got all this done for £20 i was that impressed with the quality, i'm taking loads of other stuff to be done. mainly the nuts, bolts, washers and studs that are used in the engine bay Edited August 22, 2009 by jord294 Share this post Link to post Share on other sites
mhyphenl 10 1 Cars Posted August 24, 2009 i got all this done for £20 i was that impressed with the quality, i'm taking loads of other stuff to be done. mainly the nuts, bolts, washers and studs that are used in the engine bay They look great, were they all new parts before they were done or are they just cleaned up old parts?? Share this post Link to post Share on other sites
Last Legend 0 Posted August 24, 2009 I had all the metal fittings Zinc plated on my old Concours car (the one in my sig) and within about 2 Years,guess what?they were all going rusty!You need to stop the oxgen getting to the metal to allow the rusting to begin,by all means have them plated but laquer them once fitted.its only going to take a few seconds with a spray can. Share this post Link to post Share on other sites
jord294 87 Posted August 24, 2009 They look great, were they all new parts before they were done or are they just cleaned up old parts?? old parts which i cleaned up a bit. i've just taken a box full of newer bits to be done, so hopefully they'll be back by the end of the week Share this post Link to post Share on other sites
EdCherry 34 1 Cars Posted August 24, 2009 Jord how did you clean them up, bit of wire wheel action? Share this post Link to post Share on other sites
jord294 87 Posted August 24, 2009 Jord how did you clean them up, bit of wire wheel action? basically yeah. i also have a die grinder with roloc attachments which i use Share this post Link to post Share on other sites
ALEX 98 1 Cars Posted August 25, 2009 (edited) Don't be going to Peugeot for clips, screws and fixings! There's loads of places that will sell you what you want off the shelf for a 1/4 of the price. I'm replacing most of my rebould with Stainless steel fixings. IMO anything smaller than M8 should be stainless anyway. Remember to use a plastic washer though if your fixing down anything that is galvanised, zinc or nickle coated! Edited August 25, 2009 by ALEX Share this post Link to post Share on other sites
jord294 87 Posted August 26, 2009 here is a pic of everything else i've had done. this time it only cost me £10 plenty of double ended studs for rear beam in stock now, along with the offset washers i'm really impressed with the finish of the exhaust and intake manifold studs all i've got to do now is wait for another company to do the chroming of some other parts Share this post Link to post Share on other sites
