wardy18 33 1 Cars Posted August 15, 2009 Can someone please confirm before i buy the car that the Citroen Xantia 1.9TD has the same XUD9 engine as fitted to the 205 1.9 Diesel?! Ive done alot of searching and im 95% sure it is Share this post Link to post Share on other sites
jimistdt 1 Posted August 15, 2009 Can someone please confirm before i buy the car that the Citroen Xantia 1.9TD has the same XUD9 engine as fitted to the 205 1.9 Diesel?! Ive done alot of searching and im 95% sure it is There wasn't an XUD9 205 as far as I'm aware, XUD7, 1767cc (IIRC) Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted August 15, 2009 Quote from Wikipedia if you tyore in 205 The diesel models employed the XUD PSA Diesel engine, lifted from the Citroën BX which was introduced in 1982. These XUD engines has a capacity of 1769 cc (XUD7) and 1905 cc (XUD9) Share this post Link to post Share on other sites
jimistdt 1 Posted August 15, 2009 I'm always willing to be educated - but the XUD9 was in the 405 - I've never heard of one in the 205 from the factory. I'll watch with interest.... Share this post Link to post Share on other sites
Lan 24 1 Cars Posted August 15, 2009 the xud9 is in the last of the 205's jim, i actually asked the other day whilst getting parts because i was curious as it was mentioned on servicebox Share this post Link to post Share on other sites
Sandy 191 Posted August 15, 2009 Servicebox lists the XUD9 as a 205 engine. Share this post Link to post Share on other sites
welshpug 1,737 Posted August 15, 2009 only without a turbo IIRC. Share this post Link to post Share on other sites
jimistdt 1 Posted August 15, 2009 Fair play - to nick your sig Wardy, I've learnt something today. Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted August 15, 2009 excellent as I can buy a whole citroen xantia 1.9 td for 100 quid, the block is all I need thou but can't resist to keep stored Share this post Link to post Share on other sites
jimistdt 1 Posted August 15, 2009 excellent as I can buy a whole citroen xantia 1.9 td for 100 quid, the block is all I need thou but can't resist to keep stored Has that got the FMIC? Would you be needing that and the inlet manifold? I'd be interested if you don't want them. Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted August 15, 2009 all yours mate, ill get in touch when I get the car Share this post Link to post Share on other sites
foreigner 0 Posted August 16, 2009 I believe it's the same engine, however someone told me they had to change bellhousing. So let us know if it fit on the 205 gearbox. Thanx Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted August 17, 2009 ah ok, well its going to be kept in stock as a future project but with that in mind i will also take the gearbox and store that just in case i need to swap things over, i will however try and fit a BE3 i have as a spare and report back!! Share this post Link to post Share on other sites
Hilgie 16 2 Cars Posted August 24, 2009 The bellhousing change is only needed if you fit the later 1.9 diesel, called the DW8. Share this post Link to post Share on other sites
