decoc182 0 Posted August 12, 2009 Dumb question guys, will a 309 SD 6 point bolt in cage fit a 205? Are they similar fitment? Share this post Link to post Share on other sites
Baz 421 Posted August 12, 2009 Probably similar, but different and will need modification i'm sure, so IMO hardly worth it as it'll make the cage possible unsafe, well, will certainly void any certification it may have. Share this post Link to post Share on other sites
decoc182 0 Posted August 12, 2009 Does anyone know the difference. What changes would likely need to be made? I have found a cheap SD for sale you see. I was always under the impression the 205 and 309 shared similar floorpans/chassis. Learn new stuff everyday Share this post Link to post Share on other sites
pug_ham 241 3 Cars Posted August 12, 2009 To start with I expect the 309 cage will be sligtly wider to match the bodyshell so it would need trimming down to fit snugly inside a 205. Graham. Share this post Link to post Share on other sites
Rich_p 23 Posted August 12, 2009 The 309 has a longer wheelbase too I believe so that means the rear mounting points could be further back. Share this post Link to post Share on other sites
Baz 421 Posted August 12, 2009 The floorpan is actually quite different. Some 309 cages mount to the rear arches, and the sills of 309's are very boxy, protruding into car more-so than a 205, so the cages don't need a box, just a plate to mount them... There's probably a few more points too... Share this post Link to post Share on other sites
omega 82 Posted August 12, 2009 Does anyone know the difference. What changes would likely need to be made? I have found a cheap SD for sale you see. I was always under the impression the 205 and 309 shared similar floorpans/chassis. Learn new stuff everyday buy the cage if its cheap stick it on the 309 owners forum make some money then buy the correct item Share this post Link to post Share on other sites
