A2TheA
What Is The Blackbox...
A2TheA
under the scuttle panel on the passenger side of the car?
vacuum accumulator for the sunroof.
Ryan
Yes. It stores up a bit of vacuum so that you can still use the sunroof (a couple of times anyway) with the engine off.
A2TheA
so if i accidentally took the pipe off would i be able to replace the vacuum when i start the car again?
Daviewonder
as long as you put the pipe back on yes :)
A2TheA
thanks. i scared myself when taking the engine out.
as long as it goes back to normal.
Thanks All
Aaron
