Scooby Max
8 Valve 1600cc
Scooby Max
So who's got a powerful competitive 8v modified engine..?
What specification would you recommend for rallying, without
going into silly money..?
If there is such a thing..? <_<
Max
What's silly money?
I dream of a fairly simple L&B'd hi-comp. 285ish cam'd 1.6 on TB's for my rally car with circa 150bhp. Still would be a couple of £k though...
are you limited to XU? you could go TU, or even TU16v....
Scooby Max
I did fancy the idea of going for a 1400 16v but soon realised
it was mega bucks..!
That's why I thought I'd stick with a competitive 8 valve motor..
So who's got one..?
I meant 1600 16v which is a factory engine, not 1400 which is a complete specialist build.
I know someone in my motorclub that's running a later 110 bhp version from a 205 XSi in his 205 with EFI management and a cupcar spec exhaust manifold for roughly 130 bhp, he's looking to install some cams quite soon to take it to 150 bhp+
Scooby Max
That sounds interesting..! Which 16v head is he intending to use?
Scooby Max
What's silly money?
This sounds along the lines I was thinking of..
What sort of realistic bhp / torque limit is achievable with standard pistons and crank..?
Max
its a completely standard engine <_<
James_R
Have a look on Guy Crofts website, think he did a 1600 8v wally engine made good numbers
Scooby Max
Hi Welshpug,
I take it you mean a 106 XSi..?
If so, how much modification is required for fitting i.e. mounts etc..?
Max
alync406
I think he means an engine out of a 206 xsi,they would be much the same engine as a 106 gti.
Batfink
206 has bigger valves
Saveit
I am currently building an 8v 1600cc engine. It should produce around 180 bhp, but we wont know until it has been RR'd. We took it to a rolling road last sunday but it sprung a leak while mapping it (EFI management). Seems that the headgasket have now gone since its blowing all the water out through the expansion tank and getting too warm.
Scooby Max
So how much modification is required then for fitting into a 205 i.e. mounts etc..?
The question is.. Ideally, If I'm trying to keep within a budget of less than £2000
Will I be best going down the 8 or 16 valve route for £££ / bhp..?
Edited by Scooby Max
stuart
Just noticed this thread Max, I'm actually building another engine for mine at the moment to a similar budget so give me a call if you need to know anything.
It's still at the machinists at the mo having the bottom end lightened and balanced with new pistons & liners (mine were too worn to reuse) and I have a worked head with rally cam to go on with twin webers, so hoping for around 140-150bhp when it's all up and running.
To fit the 206 xsi / 106 Gti engine and gearbox isn't a lot of work, just involves moving the gear linkage on the subframe I think and then the wiring obviously. I don't think the gearboxes on them are the best though and I think they're also heavier than the xu engine. I think costs would be similar in the end, although it's easier and cheaper to get more power out of the 16v.
So you're looking at doing the modifieds next year then?
