Lan 24 1 Cars Posted July 13, 2009 i was just fitting some seat belts to my car this morning and couldnt get them to move, While i pulled on the belt to unravel it it just engaged the locking mechanism, does anyone know how to make belts work? thanks Lan Share this post Link to post Share on other sites
Anthony 1,000 Posted July 13, 2009 Have you mounted them in the car? They only work properly when mounted at the correct angle, so if they're laying loose they will lock. Share this post Link to post Share on other sites
Lan 24 1 Cars Posted July 13, 2009 ive mounted one, still doesnt seem to budge though Share this post Link to post Share on other sites
pugpete1108 62 1 Cars Posted July 13, 2009 as anthony said it needs to be at the correct angle for them to unravel. not sure what that is mind you. i managed to unravel mine easily off the car by holding them on a vertical wall and pulling them slowly. Share this post Link to post Share on other sites
engine killer 5 Posted July 13, 2009 if they are the front one, either mount them in or keep them upright. if they are rear, they only work in one angle with about 45 degree. if they got raveled all the way, you have to pull as much out as you can and then let it ravel and slow pull again, make sure in the right angle. I have bought a set of red seat belt last month, they were exactly like you said - impossible to unravel. it took me about 2 hours with patient to unravel them all. you will get there eventually if you are very patient. Share this post Link to post Share on other sites
steve@cornwall 100 Posted July 13, 2009 Before fitting the belt, look at the back of the reel. one one side you will be able to see coloured plastic components (so far I've come across white, yellow, green, orange). This is the device that locks according to angle. Carefully remove the black cover from the reel. (push the centres from the clips to release) You will see a toothed wheel and a plastic pawl that locks it, controlled by a ball bearing. Disengage the pawl and, holding it dis-engaged, allow the belt to retract a little. you will now be able to pull the belt free and re-assemble the casing. Wedge it with something to stop it retracting while you fit it. Share this post Link to post Share on other sites
