Jamie1.9 0 Posted July 5, 2009 Hello all, I wonder if you could shed any light on the following problem. I have discovered some strange dents in my boot floor, they're pointing upwards by about 5-10mm as if something has struck the surface from below. The dents are directly in line with the rubber sandwich rear beam mounting/damper mount on both sides! I'm getting worried as these dents are beginning to rust - although I've checked the floor and it's not in a bad condition. I've removed surface rust and coated with Hydrate 80 on the underside. I can't figure out what's going on here, as; I can never hear anything striking the boot floor Beam moves as it should Dampers work correctly There are no weird handling issues Maybe the previous owner been jumping humpback bridges? Share this post Link to post Share on other sites
hengti 2 Posted July 5, 2009 (edited) i think that kind of deformation's normal once you start seeing corrosion in thin (load bearing) panels like that. i'd not worry about it personally, but could clean it up and paint on both sides of the panel if you're concerned Edited July 5, 2009 by hengti Share this post Link to post Share on other sites
Jamie1.9 0 Posted July 6, 2009 Sounds about right - you're right the metal is very thin. I had to weld a small area near the seam at the back after I poked it too hard with a screwdriver from underneath I have rust paranoia after discovering and fixing the front inner arches / headlight panel Share this post Link to post Share on other sites
