foreigner 0 Posted June 25, 2009 Will it fit? It's from Volcane TD and the one on 306 is shaooed. I wouldn't bother but 306 got another 7 months mot so need to use it up? Any ideas? Share this post Link to post Share on other sites
Baz 421 Posted June 25, 2009 Essentially the same beam yes, but i'm sure someone will confirm for sure! Share this post Link to post Share on other sites
DaveW 6 Posted June 26, 2009 I would say yes its the same car underneath pritty much. Share this post Link to post Share on other sites
Anthony 1,003 Posted June 26, 2009 It'll fit fine - I've put a 306 beam onto a ZX before now, so absolutely no reason it won't work around the other way The only thing that you might have to swap over is the part that the brake line mounts attach to, as they're different between ABS and non ABS cars in my experience, but that's only two bolts per side to swap and very easy with the beam off the car. Share this post Link to post Share on other sites
welshpug 1,737 Posted June 26, 2009 yup, same part numbers for most of the bits the Volcane beam may well have larger torsion bars and ARB, so it'll end up a good upgrade as well as less toe in on the rear arms certainly a trend I've noticed on sporty ZX's and Xsara's, is that they're slightly stiffer at the rear than the 306. Share this post Link to post Share on other sites
