pugpaul
Window Help!
pugpaul
The drivers window slowly moves down when driving, only a few inches. It can also be pushed down the same amount.....any ideas? Its a manual window.
steve@cornwall
Worn winder mechanism - replacement time :P or convert the mechs to electric?
pugpaul
Thank you mate!
I will replace with another manual. Is it an easy/expensive job?
steve@cornwall
Thank you mate!
nice easy job, if a bit fiddly. Either get a mechanism from a scrappy after making sure you can't pull the glass of the donor car open by hand (common problem on the 205) or see if a local member has a good spare - I'd expect to pay 5 -10 for a good s/h mech
