mickie
Wiring Woes
mickie
could anyone identify these wires/plugs please
been searching a lot and found mainly everything i need to know about the engine loom bar a couple of things
would the green/yellow be earth ? not sure of black wire
is this one for the radiator thermostat ? im not sure as this connection is wrong for whats on the rad
the 2 little wires i think are horn, red plug and yellow plugs i have no idea, 2 on nearside and 1 on offside
i may add to this later when i look over interior loom, when i took the loom out the car i took pictures of everything but the harddrive is now toast, i'll not be doing that again
cheers
Edited by mickie
Plug is for rad fan switch, it is the earlier pre-90 type switch you need to match it.
The yellow plugs are for earths, plug into the earth blocks on the headlamp panels either side.
mickie
so first pic is earth ? and i think the black one is for the low brake level sensor after thinking back 2 yr
2nd pic, does plug into the radiator then ? i just need a matching switch ?
cheers, for the last pics, i think im missing the earth blocks then and that red connection i think is for a second radiator fan after searching more
im getting there :blink:
M_R_205
i think th black plug on the first pic goes to the strut top earth, the brake fluid wiries are attached to the bit of loom that connects to the wiper motor,
mickie
interior loom this time
i know blue, gray and black plugs are for hazard, heated rear screen and front fogs but i dont know what connects to what
the brown plug and other plugs i have no idea about
Edited by mickie
CosKev
Brown one in bottom pic is a earth plug,plugs onto steering column area above ignition barrel????
Is brown one in top pic the one that plugs into engine loom?????
mickie
cheers i'll look into that bottom plug
no the 2 engine looms are plugged in, ive worked out the black plug is for hazard switch. bought the switches on ebay so they should be straight forward
it would be cool if i could find a link for how to make a racing loom
CosKev
Brown plug in first pic looks familiar :lol:
Do 205 Gti's have dashboard light dimmer switches in the lower column cover like 309 Gti's do?????
