Alfie 6 Posted June 2, 2009 If I needed to replace my ECU, it has the 162 printed on it. is this likely to be a two or three row ECU? Luggy is trying to help me out now with my non start problem. Share this post Link to post Share on other sites
luggy 13 Posted June 2, 2009 http://www.taylor-eng.com/ecu/motronic_intro.html Might be of some help Share this post Link to post Share on other sites
welshpug 1,737 Posted June 2, 2009 According to ATP's listings its a; BX 1.9 litre 8 Valve Cat/309 GTi 1.9 litre 8 Valve/ Bosch Motronic 1.3 0 261 200 162 the Motronic 1.3 listed for a 205 is 160 if you want to know how many rows it is, uplug the ecu.... Share this post Link to post Share on other sites
petert 641 Posted June 3, 2009 (edited) Late model Motronic 205's sold in Australia, had both 160 and 162. Absolutely no difference other than part number. Both are Motronic 1.3 (3 row). I have a couple of each if you need one. If fault finding, you can also fit a 3 row from an Mi16. eg 158/161/354/355. It will register a fault, as no knock sensor is fitted, but it will start and drive (with fault mode ignition timing). Edited June 3, 2009 by petert Share this post Link to post Share on other sites
