dino20vt
Dimma Split Rims
dino20vt
Hi, ive heard that seperating the centre thats bolted to the rim can disturb the seal, or have i got the wrong end of the stick?
dino20vt
Is it DIY?
205turbo
I'm sure Henry will tell you when he comes online, i remember he did the ones on the 309 4x4 dimma, he had once
dino20vt
Ok mate, cheers, you even pre'empt him!
Guest Rallyesmoker
That is possible.... the sealing is quite old and the rubber sealing won't seal as it should be, when you replace it. ONLY when you seperate the two rings also. Be aware!!! Only the centre is not sealed!! Take of your tires, and you could try to keep the two rings together, something I rather won't do, because is might go leaking.
You could do 2 things. Order some new sealings, OR just get some sealer at the market, transparent silicone kit (bison perhaps?) and glew them to getter. DO use the old sealer ring, because this is also a spacer ring.
Looking for some new bolds, you can take a look at www.titanium-touch.de
Done it miself, works great.
Edited by Rallyesmoker
dino20vt
Thanks for the info, it all sounds like too much work for me, the reason i wanted to remove the centre from the rims was to get them refurbed - powdercoated, which would have meant just handing the centres over, job done, no tyres to remove. So then i briefly thought about just getting the tyres removed and giving Tony the whole alloy but will the baking process ruin the seals?
Guest Rallyesmoker
The seal will survive the backing, but everything is colered, also the rims en bolts....
Taking out the centre without taking of your tires can't....
dino20vt
Im not sure how the powdercoat process works but can the emamel be just put on the centres with the aid of masking etc? If the seals would survive then maybe the tyres too?
Guest Rallyesmoker
take some tape and a spraycan..... When you do that, it's a shame and a waste of time and money to get powdercoated centres. Men, sorrie, but when you powder coat something, do it right.
Besides, before coating, the product must me blasted, clean of all kinds of dirt. Masking the rings is no garantie that they won't be harmed, evenso when they are coated, it might get on the rings.
But, yes. you could mask the rings.... and bolts :lol:
t16ryan
There easy to do yourself, i reused the plastic gaskets and used a bead of clear silicone when refitting them,
blue_haddock
Try and speak to Mark_R on here - he recently did a cracking job on refurbing his dimma rims.
dino20vt
Mark_R cant find him mate
