steve@cornwall 100 Posted May 23, 2009 I fitted a 4 branch magnex to the CTI, into a s/s flexi joint and from there to a standard 3 piece system using the last foot or so of standard downpipe. It rattles like loose baffle plates . I originally used it with magnex centre box and standard back box, which I replaced as I thought the baffles were shot and hence the rattle. However, I haven't cured the rattle. It seems to come from the knuckle joint which has new (escort diesel) springs on it. Anyone else had / cured such a rattle? It's only at load with low revs BTW, not on idle . Such a PITA I,m thinking of going back to standard manifold Share this post Link to post Share on other sites
hengti 2 Posted May 23, 2009 the only rattle i had from mine was when the blanking piece between the four pipes (in the collector) fell out - you'd know if it was that though, as it'd be blowing badly if you trace it to the knuckle joint (they're lots of trouble), it's worth ditching it for a flexi, as they're quite a good manifold (imo). i had the pipe-to-headflange welds re-tigged when mine was done as well as some had cracked Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted May 23, 2009 ive had 2 now on different and they rattled like a b****h and sounded horrible, on my race pugs system i have one of these fitted but i cut the knuckle joint off and bought a flexi joint off ebay and had it professionally welded in place, u need somethin at the end of the 4 branch so stop the vibrations throu the rest of the system, have a look here CLICKY hasnt failed me yet Share this post Link to post Share on other sites
steve@cornwall 100 Posted May 23, 2009 ive had 2 now on different and they rattled like a b****h and sounded horrible, on my race pugs system i have one of these fitted but i cut the knuckle joint off and bought a flexi joint off ebay and had it professionally welded in place, u need somethin at the end of the 4 branch so stop the vibrations throu the rest of the system, have a look here CLICKY hasnt failed me yet I have one of these after the knuckle as there was a very badly welded sleeve on the end of the pipe, so I replaced it with one of these - maybe time to look into getting the knuckle tig'ed together you think? Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted May 23, 2009 if u already got a flexi joint in place after the knuckle then yeh I'd say definitely weld it up even if you just put a couple of tacks to hold them together, I'd do the whole lot thou as you may be loosin A bit of back pressure outta it, I little hard to do the whole lot thou while in place on the car Good luck, let us know how it goes Share this post Link to post Share on other sites
rubyna 4 1 Cars Posted May 24, 2009 (edited) I have the Magnex 4branch on my 205 but my system must be an exception to the rule as ive never had a bit of trouble with it no blowing nothing, the joint has allways been greased and moves freely it has the original springs aswell which i think helps.As has allready been said perhaps welding the full flexi will help, it isnt rattling against the subframe isit? as i remember my brother having the same trouble but only on idle ,he sorted it the end if i remember correctly by using a certain gasket, i,ll have to check what -1 he used.. Luke.. Edited May 24, 2009 by rubyna Share this post Link to post Share on other sites
xxvickyxx 0 Posted May 27, 2009 mine rattles really badly aswell Share this post Link to post Share on other sites
steve@cornwall 100 Posted May 27, 2009 mine rattles really badly aswell Mine will be taken off and welded, but not for about 3 weeks Share this post Link to post Share on other sites
munster 0 Posted May 28, 2009 Another one here. My one has a lovely rattle at 3,000 rpm. From what i could tell, it was coming from the backbox. I didnt realise this was a common thing on Magnex. It seems the backbox is welded to the main pipe, so what is best way to replace the back box one one of these systems? Weld another lenght to my new backbox, and cut the old Magnex box off? Share this post Link to post Share on other sites
TRYNKEEPUP 0 Posted May 28, 2009 mine rattles aswell. Its the back box on mine does it when ticking over sounds awful, sent it back to magnex once to have it sorted lasted about a fortnight i think !! Share this post Link to post Share on other sites
