Bassman 1 Posted May 16, 2009 Hello, My JCB trolley jack seems to lower over time with or without load. It will lift the car fine and I can place the axle stands to support the car, but I usually leave the jack under as well as a backup, but I have noticed it will lower after a couple of hours. I managed to find the manual and topped up the oil (it was a bit low) and did various things it suggested to bleed out the air by removing the oil bung and pumping the handle etc, but it still seems to lower over time. Any suggestions? Have I knackered it letting it run low on oil perhaps, although it always seems to lift with no complaints? Rob Share this post Link to post Share on other sites
Ryan 99 Posted May 16, 2009 I though most hydraulic jacks gradually lowered over time. Just that some do it faster than others. My Clarke jack does it too - although it's a cheap piece of crap, so if it's not supposed to then that wouldn't surprise me. Share this post Link to post Share on other sites
welshpug 1,737 Posted May 16, 2009 Quite likely a seal kit will stop it doing so, my 6 year old Clarke 1.5t jack doesn't do it and its been hammered! Share this post Link to post Share on other sites
Bassman 1 Posted May 16, 2009 Quite likely a seal kit will stop it doing so, my 6 year old Clarke 1.5t jack doesn't do it and its been hammered! Oh ok, when I get back to the UK I will see if I can pull it apart and see if there are any obvious seals that I can replace. I wasn't sure if these were serviceable as it was only about 30quid from Halfrauds, but perhaps they can be. Rob Share this post Link to post Share on other sites
xxvickyxx 0 Posted May 19, 2009 I found its easier to just buy another cheap one Share this post Link to post Share on other sites
JeffR 51 Posted May 25, 2009 (edited) I've just had my 50 year old Bradbury trolley jack reconditioned because of the same problem-I'd jack the car up, go & have lunch & an hour later the car would be on the ground again! Is there any telltale leaks from yours indicating likely seal failure? I'd take Welshpugs' advise & get a repair kit for it, or pick up a new cheapie. Good Luck. Edited May 25, 2009 by JeffR Share this post Link to post Share on other sites
Rippthrough 98 Posted May 25, 2009 They all do it somewhat, I flushed the fluid out in mine and replaced it with a 10w damper oil, much better. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted May 25, 2009 I had a Clarke on that did this & lost oil within its 12 month warranty so I took it back to ask about a warranty claim but the branch of Machine Mart I got it from said once it was reconditioned I'd only get the remaining time of the original 12 month warranty with it so I asked if I could return it for a refund instead. They said I could so I did & bought a draper one & thats still good nearly ten years later. Graham. Share this post Link to post Share on other sites
jackherer 543 Posted May 29, 2009 They all do it somewhat, I flushed the fluid out in mine and replaced it with a 10w damper oil, much better. I filled mine with some Citroen LHM hydraulic fluid I had in the garage, it worked very well compared to Halfords jack oil. Share this post Link to post Share on other sites
GeorgeXS 32 Posted May 29, 2009 My 70's jack is filled with automatic transmission oil, works a treat!! Share this post Link to post Share on other sites
