timb1046
Ignition Wire Colours
timb1046
i know this has been covered before as i remember reading the topic, but having done various searches to no avail im asking again,
i need to know the wire colour that comes from the ignition barrel to the coil. the problem is my wiring has been butchered by a previous owners fitting several alarms to it in its past so no wire #s can be seen just the initial colour coming from the barrel. any help appriciated, even if its eliminating wires.
Tim
timb1046
anyone? or anyone with a better diagram of it than the haynes? any help, realy would be appriciated.
Regards
Tim
there aren't any wire numbers between the ignition switch and the fusebox IIRC.
only 2 plugs, one goes from fusebox to switch, the other from switch back to fusebox.
easy enough to trace backwards though, the connections to the fusebox are shown on the wiring diagram, and there's a corresponding diagram showing where those plugs are on the fusebox in the Haynes manual, more than enough to go by.
a multimeter that beeps or a power probe will help a lot B)
pugpete1108
from what i can gather its the thick red wire from the ignition switch, number 2
but thats only from what others have said on here so dont take it as gospel
best to test it with a meter B)
nope, wire 2 is on the fusebox to engine side, NOT the ignition switch.....
