tezza 0 Posted May 5, 2009 hi guys, wasnt sure where its best to post this so thought i would try and here. please move if its in the wrong section. Anyway after starting the car the other day i smelt fuel. looked underneath and it was spraying out of one of the fuel pipes. Where am i able to get two new ones of these? and how much am i likely to pay? thanks very much in advance Share this post Link to post Share on other sites
jord294 97 Posted May 5, 2009 genuine fuel lines from main dealer, cost about £15 it's only one length, but long enough for the 2 lines, and you'll need to bend it yourself Share this post Link to post Share on other sites
tezza 0 Posted May 5, 2009 thanks mate. dont they sell exact fit jobbies with the right end connections? Ideally im after a direct replacement, as one of the current ones has so many hoses connecting it where its obviously been rotten and the previous owner bodged it together. also how hard are they to replace? Share this post Link to post Share on other sites
Alan_M 66 1 Cars Posted May 5, 2009 Fairly easy, just long winded to change. Hardest bit is undoing the unions on the bulkhead. I replaced mine with 10m of copper pipe from B&Q, cost £10 I think. Used 2 petrol pipe jubilee clips on each flexi and its been spot-on since. Just got to be careful with copper tube, as if your a bit heavy forming the run, the walls can collapse. Share this post Link to post Share on other sites
tezza 0 Posted May 5, 2009 thanks mate. is there a braided equivalent? i assume that would be expensive. the car will be used for track days so i want something reliable Share this post Link to post Share on other sites
Guest 80wya Posted May 5, 2009 (edited) baided is an option but if u do go for PTFE lined lines not nitrile rubber inside the car. the rubber stuff smells and can cause headaches etc.. no smell with ptfe.. the rubbers alright to use under the engine bay tho.. and more flexable for tighter loops needed runnin round the engine. PTFE lines will require the propper fittings tho as they DO NOT clamp down using jubilee clips. will have to post a blog soon showing mine. Edited May 5, 2009 by 80wya Share this post Link to post Share on other sites
Alan_M 66 1 Cars Posted May 6, 2009 thanks mate. is there a braided equivalent? i assume that would be expensive. the car will be used for track days so i want something reliable I've had those lines on for over a year now including a good thrashing round the 'Ring, and had no problems with them whatsoever. Share this post Link to post Share on other sites
