Silky 33 1 Cars Posted April 27, 2009 My brother is in the middle of restoring a MK3 Capri. He is onto the electrics and is a bit stuck with the ignition barrel wiring. There seems to be a red/blue/brown group of wires which connect to the dash wiring via a male/female plug and that is all fine. However, there is a yellow wire coming off the barrel with a female connector, there is a male connector in the dash loom with a yellow wire, all connects up well. However the yellow dash wire doesn't actually go anywhere and looks as though it has been cut or snapped off of something, I think it's a 12v suplly wire but have no idea where it should go to. Anyone got any experience with these cars or wiring (I am useless with elec's) Thanks Share this post Link to post Share on other sites
jplautomotive 0 Posted April 27, 2009 My brother is in the middle of restoring a MK3 Capri. He is onto the electrics and is a bit stuck with the ignition barrel wiring. There seems to be a red/blue/brown group of wires which connect to the dash wiring via a male/female plug and that is all fine. However, there is a yellow wire coming off the barrel with a female connector, there is a male connector in the dash loom with a yellow wire, all connects up well. However the yellow dash wire doesn't actually go anywhere and looks as though it has been cut or snapped off of something, I think it's a 12v suplly wire but have no idea where it should go to. Anyone got any experience with these cars or wiring (I am useless with elec's) Thanks ign yellow on old fords is for radio ign feed most werent used cause they didnt came with radios Share this post Link to post Share on other sites
Retro Pug 0 1 Cars Posted April 28, 2009 ign yellow on old fords is for radio ign feed most werent used cause they didnt came with radios Agreed should be the switched live for the radio. Share this post Link to post Share on other sites
Silky 33 1 Cars Posted April 28, 2009 Cheers fella's, will let him know He's got loads to do still so I may be back on here with some questions if either of you (or anyone else) or old ford experts Share this post Link to post Share on other sites
