Guest rmilbank Posted April 24, 2009 Im currently building an XS for short oval racing. Im wondering what peoples ideas are on specs for suspension setup. I need to retain standard dampers but springs are free. I was thinking some Grp N mounts front and rear. GTi torsion bars and perhaps ARB from a GTi?? (will this be too stiff)? As for front what springs are best rated to fit the XS? I previously had a thread that says GTi springs suit. So whos best and how low? Eibach/Apex/Pi... 30/40/50/60mm drop?? Share this post Link to post Share on other sites
ericdean 0 Posted April 25, 2009 Hello Mate Which track(s) are you planning on racing at? I used to race a 2Ltr Pinto'd Starlet at Blyton (Lincolnshire). I would go for a set of poly bushes for the front, and a set of Grp A solid rear mounts. As for how low to go will, I would've thought, depend on the track you run on and the pits, last thing you want is to be dragging the floor all through the pits! Eric Share this post Link to post Share on other sites
Guest rmilbank Posted April 25, 2009 I live around 10 minutes from Arena Essex so will be racing there mainly. the track is pretty smooth but the pits are quite bumpy. Is the best idea to get it as low as possible or will that just cause it to shuffle and hop in the corners? Share this post Link to post Share on other sites
ericdean 0 Posted April 25, 2009 That was always my idea, as low as I could but without making it stupidly stiff, when I ran the small 13" steelies on dry tyres I had to drive it up onto 2 bits of scaffold board to get the jack under! It will need a bit of give otherwise it will shuffle about. It would be worth a trip down to the first meeting and have a look at few of the other cars and chat to the drivers to see what they're doing. Share this post Link to post Share on other sites
Jrod 7 Posted May 5, 2009 Euro rods? If so then you can uprate the front left shock iirc? After a break from endurance rallying we were testing my mates euro rod at worthing this weekend and it went quite well. Share this post Link to post Share on other sites
