Rich_p
Pts Bilstein Coilvers / Inserts.
Rich_p
I may have found some made up PTS coilovers for sale.
The only thing is the inserts could be gravel ones.
Will this be an issue at all if running stiffer springs for track use?
The rear shocks are the generic gravel/tarmac group N billies anyway
If you're using them for track use you ideally need the tarmac inserts, the gravel ones will be well under damped and banging on some bigger springs won't help at all.
I'm after some gravel ones though, maybe we could do a swap for a set of my tarmac ones or something!
Rich_p
That could work, I’m hopefully getting some pictures at some point and we can go from there.
I’m not sure if there are the long or short spindled versions.
If they will be under damped is there any problem with running thick TB’s on the back with group N dampers as they are gravel spec aren't they?
philfingers
you want Tar ones really as Baz has said. Also the rear can be tar or gravel too. uprated TBs would probably be better with tar rears but you could try them with gravel ones. It's a lot about personal choice really.
Pretty much all will be long top these days
phil
