Lan
Xs Exhaust
Lan
ive been searching on the forum and found a few threads about exhausts and wanted to confirm, could i swop out the centre box on my xs for a pipe from a 1.1 engine??
thanks
AdamP
thanks
Neither my Roland Garros or the XS I broke had centre boxes, however the XS had a bigger back box on it so it wasn't any louder than standard! Weird ehh.
j_turnell
Yes you can, i did this on my old XS back in the day, sounded good with a Px filter!
one-lady-owner
Yes you can, I did it to mine as the straight through centre section was £12 and a new centre box was £60!! I was told I would lose some mid-range torque, something to do with the lower back pressure, definitely adds a bit of a burble to the exhaust note! I didn't really notice any loss of torque personally!
Edit: spelling! :)
Edited by one-lady-owner
johnnyboy666
ive just swapped my 1.1 pipe for the pipe with a silencer and it feels much more responsive and i dont go deaf on the motorway :D it doesnt sound as fun tho :P
Chuckyd
ye you should be fine i did the same on my a few weeks ago
Joshy
Sorry to thread Jack slightly but...
As far as I can tell, but XS has a standard system hooked up to a 4 - 2 - 1 manifold which does the job nicely, but the barry in me would like it to sound a bit more raspy when the needle climbs to the higher reaches of the Tacho. I don't want to lose any power, and likewise, I don't want something that is stupidly loud when pottering around town (I'd rather not draw attention to myself!).
Can anyone suggest something, or should I stay standard?
snillet
Does it ?
one-lady-owner
The standard XS doesn't have a 4-2-1........ it has pretty much the same manifold I've seen on every TU, connected to a (fairly big) downpipe.
they DO have something along those lines, just not a tubular steel effect, its along the same lines as the GTI's XU cast iron 4 -2 manifold and 2 part downpipe with the splitter, more commonly on the TU a separate twin pipe.
Edited by welshpug
AdamP
All the TU3S engines I've seen have had an ordinary cast manifold with a single down pipe :P
Sure I've seen it on a 205, I don't know which the TU3S is though.
AdamP
XS engine :P I'm pretty sure all the TU3 manifolds are the same, i've got 205 XS, AX GT and 106 XSI ones in my garage and they're all identical.
Joshy
Sorry, I meant my car has a aftermarket 4 - 2 - 1 jobbie. Silly grammar/typo :wub:
Edited by Joshy
BERTMAN
apparently using the 1.1 pipe, makes your car slightly less responsive and looses you a bit of power... sound louder though, depends if you care about power figures or not?
snillet
I can partly agree with you there, both these and the XU has got a pretty well designed manifold that separates cylinders 1+4 from 2+3 inside the manifold, which is good. I´ve even looked into prolonging this "split-wall" down into the downpipe to create somewhat of a 4-2-1 design on a budget, but i haven´t concluded if that is worth the try yet :)
