jimistdt
Is This A Serviceable Beam?
jimistdt
A quick question for anyone whos rebult a few beams please.
I've just been and had a look at a beam I've got in the shed, I've had it a while but today I decided to give it a wipe down and have a proper look at it. I gave the Shafts a little rub with some 400 wet and dry soaked with Plusgas just to get rid of a little surface rust.
A quick spray with plusgas and a wipe down with an old dishcloth
And the bearing are free to rotate
Edited by jimistdt
Lookks pretty good to me!
Look good to me, there are some witness marks where it has been in use before, but I reckon it is good to reuse. Check the bearings v carefully as I have seen some that are free to rotate but have slight flats on the rollers. TBH for what they cost I'd think about swapping them.
ALEX
looks like you dont need new shafts anyway
Have the needle bearings left any impressions in the beam tube or shafts?
Shafts look OK from what I can see in the pictures, but as a matter of course replace the seals and bearings before you put it back together
jimistdt
Happy Days!
Thanks Tom and Baz for the quick responses.
I've just had another look at the bearings and when i wiped my finger over them they looked like new, no dirt in between the rollers. But I will heed the advice and get some more bearings and seals :D
I'm really pleased about that its a bit of a faf trying to get a pair of arm shafts these days.
Edited by jimistdt
as above, looks very good.
you can get a bearing+seal kit from peugeot/citroen for about £30+ vat, if there's any sign of wear/polishing at all I'd be tempted to press the shafts out and fit them back in rotated 180 degrees, but they look fine.
jord294
up to date prices are
513145 bearing £8.01 each
513249 bearing £8.33 each
515408 seal £4.26 each
all plus vat, and i haven't put the price up for the metal ring the seal sits in
I'd say the pin with the marks on really needs replacing, Not something I would use unless dare I say it for a car I was selling
