timmsy19
Speedo Cable
timmsy19
Hi all
went to get a new speedo cable today but the stealers said there is 2 lengths listed for 1.9 8v
an 880mm and 1100mm apparently
whch one would i need for my Mi'd 205?
thanks
Short one is for LHD cars I believe.
Definately the longer of the two that you need - as Tom says, I believe the shorter is for LHD cars.
j_turnell
As above you need the longer one of the two.
timmsy19
sweet. i did think the longer of the two. its also the cheaper of the two <_<
thanks guys
Rock Lobster
How much do they want for them out of interest?
j_turnell
Last time i bought one from pug was around £28
timmsy19
think the guy said about £22 for the longer and £26ish for the shorter one
Edited by timmsy19
Super Josh
And if you are doing a GTi6 conversion, you want the even longer one from a 405, to clear the '6 manifold nicely :)
Josh
Simes
and from what I heard last week Pug sell you a universal kit which you can also buy at GSF for cheaper.
that's the accelerator cable not speedo cable :)
Simes
that's the accelerator cable not speedo cable :wub:
oh yeah, that's what happens when you try to do 6 things at once.
*oops*
I keep meaning to look into which of these two can be used on a RHD 205 because the length is only from the ball on the cable that fits against the bulkhead rubber grommet & not the whole length of the cable.
I got one for mine last year after mine died & I asked for the longer of those listed. If anything its long, more like a 405 one as suggested by Super Josh so I'm going to swap it for a better length one soon.
Graham.
timmsy19
so if it only goes from the ball on the bulthead i take it that means i wont have to take apart the dash?
Edited by timmsy19
lemmingzappa
If that turns out to be true, it's a small weight off my mind :blink:
timmsy19
yeah same here. thought it would be a right ballache to sort out. might make a nice change fixing something thats simple this weekend.
chrisj21
You still have to remove the clocks to change the cable.
I replaced mine last weekend, a pain as mine had snapped where the cable pin enters the speedo drive on the gearbox so i had to remove this to.
Only takes 5 minutes to remove the clock surround. if you remove the heater controls and panel there are two screws behind this. then remove the heater vent above, coin tray and triangular cover and there a further three screws here to remove and then one torx head to undo on the clock surround near the drivers door located through a small hole.
Pop the surround off and then theres just two screws securing the clocks to the dash. unplug the wires and the clocks will come out.
I also found it easier to remove the lower dash panel above the pedals so i could feed the cable up towards the clocks.
The engine bay part is supprsingly easy.
Hope this helps
Chris
timmsy19
thanks chris i'll have a go at it today
chrisj21
You also may have two screws located through the sterring column surround holding the speedo surround on. Forgot about these as i removed mine.
Chris
timmsy19
ok thanks Chris
well i picked up the cable this morning Pug part number 6123.c5 £23.53 inc VAT
I think you've misunderstood what I meant.
I think the different lengths of the cable are measured from the ball thats part way along the cable outer & stops in the rubber bulkhead grommit to the gearbox drive.
You still have to take the dash apart to remove the clocks to replace a spedo cable but you can get to the bulkhead hole from the footwell so only the top of the dash needs stripping down to remove the clocks & un-clip / refit the new cable end into the clocks.
Graham.
Grim.Badger
I got the longer of the two cables for my last GTi; It was far too long and ended up wrapping around itself somehow and snapped :D
mickie
ok thanks Chris
what length is this one then ? or is it just the standard lendth for a 205gti 1600/1900 ?
i was in the dealers the other day and he told me theres 6 different types..
DrSarty
And I also strongly recommend getting the cable out of the bag in the 'shop' and measuring it, even comparing it to any others they may have.
GSF bagged one up incorrectly and I ended up with a short one in a long bag, which involved a f*cking yo-yo day to and from Manchester. :P
Further to that though, in future I would always by OE from Pug, as I think they provide a smoother (less jumpy) reading over time as the lubrication gets attacked by exhaust heat.
Edited by DrSarty
mickie
any idea what the standard length is ? i'd of measured mine but i threw it away thinking there was only one type for the gti
