duke 2 1 Posted April 16, 2009 Hi everyone About a month ago now my 205 started to make quite a gastly clunk from the front left. Me being the naive tit that i am took it to a local garage who charged me £30 for the privelidge of tightening the subframe bolts which im told had come loose creating a nasty clunk. This fixed the noise...until now when exactly the same clunk is returning My question is...why is this happening basically and is it a common problem, is there a definitive fix, yada yada.... Thanks people Share this post Link to post Share on other sites
welshpug 1,626 Posted April 16, 2009 without knowing what's causing the clunk this time its impossible to say! Share this post Link to post Share on other sites
swordfish210 20 Posted April 16, 2009 I cant say i've ever has the subframe come loose on me before. You could renew the locknuts on the front mounts. Share this post Link to post Share on other sites
duke 2 1 Posted April 16, 2009 without knowing what's causing the clunk this time its impossible to say! I would put rather a considerable amount of money on it being the exact same problem as the first time - a loose subframe Share this post Link to post Share on other sites
Anthony 1,000 Posted April 16, 2009 A bit of threadlock works wonders... Share this post Link to post Share on other sites
oli-pug 6 2 Cars Posted April 17, 2009 Use a bit of threadlock on the bolts and check the condition of the arb droplinks too. Share this post Link to post Share on other sites
duke 2 1 Posted April 17, 2009 Brilliant, I was wondering if it was worn mating components but it looks as though your right and the bolts are just working loose in which case threadlock shall indeed do the trick. Thanks again Share this post Link to post Share on other sites
philfingers 5 Posted April 20, 2009 the rear ones go into a kind of captive nut which is inside the footwell. They do wear, especially if the car has been used with them loose for a while. You can buy new ones if it's an issue with them coming loose. Threadlock or lockwiring the bolts in can help. Share this post Link to post Share on other sites
