Chuckyd
Changing Driver Side Front Wheel Bearing
Chuckyd
hey ive got a 205 1.8 td a couple days ago i started to hear a wobbling noise coming from the fds whelel took wheel off and all is tight bar the brake disc/hub that has play init do u think i would be the bearing and whats the best way to replase it?
many thanks
chucky
M@tt
sounds like the bearing
Get a new bearing from GSF and then it's a case or ringing round/calling into a few garages to find one that will press the old one out and put the new one in. Expect to pay anywhere between a few beer tokens to £20 to have it done though. It can take longer than planned if the circlip and or the bearing is rusted solid! i've once had to scrap a hub as the circlip had just fused itself to the hub
As Matt says. The circlips can be a right pain to get out sometimes. I haven't failed yet though, although on one I did I had to resort to grinding a hole in behind the circlip to lever it out.
Chuckyd
thanks guys i will look at getting it done over the weekend and let u no how it goes
