Moz_Goodwood
Door Seals
Moz_Goodwood
whats the best to stick the rubber seals onto the metal work? as mine are coming away slighty in some places
would superglue be any good? as ive got some lying around
cheers
paul
willmounsey
I dont see why superglue wouldn't work but would it eat into the rubber after a while??
Tigerseal good sticky stuff and if the rubbers were replaced in time tigerseal can be removed quite easy with a bit of heat.
Will
SurGie
Try using flexible silicone, it'l stick it well and is water proof and easily removed, JD...
joe1joe
do u mean the door seal? if so u can take it off and squeeze it with ur fingers which close up the gap(there is a metel strip in there) or you are on about somthing esle ......
