mikespug 1 Posted April 8, 2009 can someone please tell me where the earth go`s on the ph2 ?? doing the rear light swap on my ph1 but couldn't get the wire loom so got to start fresh and work out wire by wire if i can find the earth point i should be ok thanks for any info mike Share this post Link to post Share on other sites
pugit666 2 Posted April 8, 2009 are you looking for the earth block on the body? its on the passenger side Share this post Link to post Share on other sites
mikespug 1 Posted April 10, 2009 no mate want to no where the earth go`s on the lights Share this post Link to post Share on other sites
j_turnell 134 3 Cars Posted April 10, 2009 http://www.205gti.com/techrearlightUK.htm Share this post Link to post Share on other sites
mikespug 1 Posted April 10, 2009 http://www.205gti.com/techrearlightUK.htm your a life saver or should i say rear light saver was going to give up and ebay them thanks very much mate o u 1 mike Share this post Link to post Share on other sites
pug_ham 240 3 Cars Posted April 10, 2009 http://www.205gtidrivers.com/articles.php?...=m-phase2lights Graham. Share this post Link to post Share on other sites
Sanchez 0 Posted June 12, 2009 I've been looking at the guide on the site and I've got everything to do the conversion. Is there a certain size the spade connectors have to be? Share this post Link to post Share on other sites
pug_ham 240 3 Cars Posted June 12, 2009 I've been looking at the guide on the site and I've got everything to do the conversion. Is there a certain size the spade connectors have to be? You can't buy the correct size spade connectors afaik, they need to be 5mm iirc but those you can buy from motor factors are 6mm so need filing down to fit the plug. I have since changed how I make the end of the conversion loom to use a modified connector from a scrapped 205 with the wires joined into that & its plugs straight in. http://forum.205gtidrivers.com/index.php?a...ost&id=4450 Graham. Share this post Link to post Share on other sites
