Rob Turbo
Gti6 Exhaust Manifold Thickness
Rob Turbo
How thick are the runners on a gti6 exhaust manifold and are they mild or stainless steel?
I'm going to be building a turbo manifold from one so need to know if the standard runners will be of any use or if I'll only be able to use the flange, I'm picking one up tomorrow but won't be able to cut it up until the weekend probably.
stainless, and not particularly!
where's the turbo going to sit?
Edited by welshpug
Rob Turbo
It's going to sit above the gearbox, like the dp engineering jobbie
Rob Turbo
Picked the manifold up just now, it really isn't that thick is it!
Not sure if I'm going to use it anyway and see what happens, or chop it down to the flange and get some new pipe, not sure where to get the pipe from though, the only place local ish to me only does stainless and don't do it thick enough!
Cameron
Its most likely to be 16swg (1.6mm), but even if it is 18swg (1.2mm) that is still plenty thick enough even for turbo use.
Rob Turbo
Really? I was under the impression it needed to be fairly thick to cope with the extra heat, I've gone and ordered some 2.5mm thick bends now so might as well use it :D
Thanks anyway, I'll bear it in mind for next time.
Cameron
Jesus!! :D
No it doesn't really have to be any thicker unless you're running serious power! The thickest material we use at BTB is 1.6mm and we've never had any problems with primaries melting. :D
An example for you, Radical primaries (Hayabusa turbo) are 1.2mm stainless.
Edited by Cameron
