davey205
Squeak From The Back
davey205
happens when breaking going at slow speeds and also when moving slowly sometimes wish i knew what it was / what to oil ? anyone else had a simular problem
Tesstuff
Rear beam, rear dampers, mouse?
Mind you , if its when you are 'braking' it could be a number of things. :)
Edited by Tesstuff
davey205
it seems to happen when breaking and shortly after breaking lol
Tesstuff
LMAO i like it :)
Edited by Tesstuff
jims205s16
i had a similar problem spent ages looking for it. always on breaking and slow speeds when hit any bump in the road
turned out to be the spare wheel had come a little loose and was moving about in the carrier
seems stupid but drove me nuts for days till i found that
worth a check as an easy fix
richsmells
Stop car. Open boot. Push up and down on boot lip.
You should be able to work out where it's coming from if it's suspension related.
Mine had similar symptoms which turned out to be knackered trailing arm shafts, bearings and beam tube.
Edited by richsmells
