Oil Filter On Vts Lump
I intend on not using the heat exchanger oil cooler thing on my vts engine - how do I fit just the filter on the block though - there is no screw, if I take the cooler off. Can i somehow remove the one from my 8v? If so how?
allanallen
you just need to screw in the hollow stud thing off you 8v engine. their a bit of a bastard to get off but it can be done. If not they dont cost a lot from peugeot.
OK, thanks. Thought this would be the case, but couldn't see how to unscrew the threaded bit, without ruining the thread! Any tips?
Alastairh
Tap a torx T45 into stud and it can be retracted easily. But they are sub £5 from memory from Pug.
Al :)
Cheers mate - I'll have a go tomorrow.
Ryan
£1.27 from Pug, part number 1103 54.
Alastairh
Perfect! What more could you ask for?
