TRYNKEEPUP 0 Posted March 19, 2009 Hi just brought a pair of new inner gaitors for my 1.9. both the same and was told they fit either side. My question before i start ripping them to bits is are they the same. the long shaft on divers side has a coke can type fitting and the gaitor goes inside this. How does it come apart do i cut old gaitor? does it pull out? and does new gaitor go over the top ? thanks Share this post Link to post Share on other sites
swordfish210 20 Posted March 20, 2009 Hi just brought a pair of new inner gaitors for my 1.9. both the same and was told they fit either side. My question before i start ripping them to bits is are they the same. the long shaft on divers side has a coke can type fitting and the gaitor goes inside this. How does it come apart do i cut old gaitor? does it pull out? and does new gaitor go over the top ? thanks Have a read through this: http://www.talk-torque.com/forums/viewtopi...f=11&t=3295 Everything you need to know should be in there Share this post Link to post Share on other sites
