jimbean 0 Posted March 12, 2009 this is our rally spec engine alloy block head has some flow work by myself liners are good with total seal rings and arp bolts crank is lightend and ballenced oil puimp has grp a spring inlet matched to head cam is piper 285 and carbs are new 45`s rolling roaded at 120 at the wheels Share this post Link to post Share on other sites
platty 1 Posted March 12, 2009 (edited) Love your flow job, dishwasher do have a use Edited March 12, 2009 by platty Share this post Link to post Share on other sites
aCe 0 Posted March 12, 2009 PMSL at the f***ing block in a dish washer! Did that work? Share this post Link to post Share on other sites
jimbean 0 Posted March 12, 2009 PMSL at the f***ing block in a dish washer! Did that work? yeah it came out mint DO NOT LET MY MISSUS KNOW THOUGH! took 3 goes but it was worth it 1 clean block/head/all pipes/sump/ infact the washer was going most of the day Share this post Link to post Share on other sites
aCe 0 Posted March 12, 2009 yeah it came out mint DO NOT LET MY MISSUS KNOW THOUGH! took 3 goes but it was worth it 1 clean block/head/all pipes/sump/ infact the washer was going most of the day Love it! How come you don't have an adjustable venier pulley? what capacity is it (if its 1900 the power seems very low imo) Share this post Link to post Share on other sites
jimbean 0 Posted March 12, 2009 Love it! How come you don't have an adjustable venier pulley? what capacity is it (if its 1900 the power seems very low imo) its a 1600 and the pully was a early one with a roll pin re drilled and locked but be honest the timing was very close to standard gti timing i had to check power band info and we are cock on reason i checked is when we had the ignition timing prob.... co driver blamed valve timing.... so it was checked and double checked it is easy to condem engine work but when it comes down to it i stand my ground.... and i was right on this occasion 1 look at dissy brought the fault straight to surface co drivers suck ass! Share this post Link to post Share on other sites
Mark205 1 Posted March 12, 2009 If its 1600, why does it have the spacer plate! I washed a carb in a dishwaser once, opened the washer to early and fuel smelled steam filled the room. OOPS. Share this post Link to post Share on other sites
jimbean 0 Posted March 12, 2009 If its 1600, why does it have the spacer plate! I washed a carb in a dishwaser once, opened the washer to early and fuel smelled steam filled the room. OOPS. spacer plate and 1.9 sump for bottom end strength trying to makr the engine strong and powerfull now all we need is the driver to rev it harder my last conversation went as follows that shift light is no good.... it never flashed once....when did you change gear? duno! well try letting the shift light flash.... rev the f***in thing!!! Share this post Link to post Share on other sites
bensonmi 4 2 Cars Posted March 12, 2009 sounds like its going to be good, any more spec on the rest of the car? Share this post Link to post Share on other sites
Baz 421 Posted March 13, 2009 It'd be good to see a graph? I'm sure you said it was 125ATW in another thread... Share this post Link to post Share on other sites
jimbean 0 Posted March 13, 2009 It'd be good to see a graph? I'm sure you said it was 125ATW in another thread... it would be great to see a graph but i don`t have 1 as i said mr bogg does not run a digital rolling road just a analog dial on wall end of the day our little 1.6 gti seeing 120ish on dial is good too me and as you can see from pics the basics are there it is out this weekend so fingers crossed we will get a good result i will get some more pics and spec of car at weekend Share this post Link to post Share on other sites
BackStreetRacecars 3 Posted March 13, 2009 very interested in the jetting of the carbs as I am contemplating something very similar very soon.... . raid the stock pile in my shed!!! What cr has the engine got too?? oh yeah.... any pics of the car?? Share this post Link to post Share on other sites
jimbean 0 Posted March 13, 2009 very interested in the jetting of the carbs as I am contemplating something very similar very soon.... . raid the stock pile in my shed!!! What cr has the engine got too?? oh yeah.... any pics of the car?? to be honest did not chect the cr it was a early 105 bhp motor so swapped head with a good 1.9 and gave it a good skim as for jetting i will be taking it back after our event this weekend want to see if we can get ant more out of her and am sorting spec and pics at mo Share this post Link to post Share on other sites
Baz 421 Posted March 13, 2009 very interested in the jetting of the carbs as I am contemplating something very similar very soon.... +1 Share this post Link to post Share on other sites
jimbean 0 Posted March 13, 2009 very interested in the jetting of the carbs as I am contemplating something very similar very soon.... . raid the stock pile in my shed!!! What cr has the engine got too?? oh yeah.... any pics of the car?? got some pics uploaded these are as it look`s at the mo some spec as follows 16 gti seam welded shell be3 1.6 box standard box with quaife atb diff/ we also have a really short be1 for twisty bits ap paddle clutch bilstien coil overs front bilstien rear shock fully rebuilt rear 1.9 axle with frodo 2500 pads brake pipes all aeraquip through car magnex full system with standard front pipe hydraulic hand brake standard bottom arms with super flex bushes oil breather front brakes 1.9 with 2500 frodo pads after this event at the weekend the engine will be getting a good once over as its finished its 3rd rally and will be nicely run in then back to tuners for some pep the only thing i might look at will be the brakes... we are running a standard set up and it might benifit some bias... but it is going well at the mo with a bit more development it will be great Share this post Link to post Share on other sites
welshpug 1,737 Posted March 13, 2009 "Frodo pads" PMSL! best misspelling I've seen in ages! no extra compression? Lumpy stick + standard 8 valve compression = horrible unde 2.5-3k Share this post Link to post Share on other sites
jimbean 0 Posted March 13, 2009 "Frodo pads" PMSL! best misspelling I've seen in ages! no extra compression? Lumpy stick + standard 8 valve compression = horrible unde 2.5-3k sorry for my dyslexia... thats why i became a mechanic and not a teacher lol as for cr head had a heavy skim but i did not calculate the ratio it was too much like hard work and it does like high revs Share this post Link to post Share on other sites
BackStreetRacecars 3 Posted March 14, 2009 looking good!! Always like see purposeful looking 205s.... only thing i'd like to see extra on there is a timing belt cover!!! Share this post Link to post Share on other sites
