watford1gti 0 Posted March 8, 2009 right ive been restoring the miami and now bits are starting to go back on, im working in the n/s front arch however i dont know what stuff to put underneath, when i was stripping it there was this type of foam stuff that they had obviously sprayed on, i want to try and find some stuff like this because it fills the gaps and corners quite nice. ive got some underseal stuff but its in a tin like a paint, you can build it up a little but doesnt get in the edges and corners enough. any ideas what they sprayed on it when they made them? cheers matty Share this post Link to post Share on other sites
Guest baileysufc Posted March 8, 2009 tbh it sounds liek for a a sprayable seam sealer tbh rather than a wax does that stuf your on about dry ? is it hard or soft? Share this post Link to post Share on other sites
CosKev 16 Posted March 8, 2009 If you want the best use this: http://www.rust.co.uk/epoxy-mastic.cfm Expensive but is the best Using it on my Evo V at the minute,do it right!!!! Then nice white finish for top coat: Share this post Link to post Share on other sites
Last Legend 0 Posted March 8, 2009 Wurth products are always considered good in the trade,I'd also check out their stonechip before making a decision. Share this post Link to post Share on other sites
