swinney88
Can I Take The Power Steering Pump Off
swinney88
i've just sourced a 205 engine got it off a mate on here and his car had power steering and mine doesn't. Before i fit it can i simply take off the power steering pump and pulley wheel and use a normal alternator belt.
Edited by swinney88
dcc
if you have the original engine, which didnt have the P/S pump, can you not just swap accross what ever is different in the arrangement?
You'll need to swap over the alternator/PAS mounting bracket on the block as well, but it's straight forward enough and obvious what you've got to change when you've got the two engines in front of you.
Veero
If you do I know someone who is looking for an 8v PAS pump.
PM me and I will pass on the details if you are looking to sell it.
